- Joined
- Jan 8, 2009
- Messages
- 376
- Points
- 1,528
Hey if the fuel pump does not sounds right then it probably is the reason of hesitate RPM, do you have a fuel pressure gauge installed with your after market Fuel Pressure Regulator ? Can you recall the suppose fuel pressure ?
Also how old is the fuel filter ? Do you think it might be clogged ?
Bro, thanks for your reply. My Sard fuel regulator is come without the gauge but I got Defi fuel pressure gauge inside cabin. It show 2.8 at idle, when giving gas it will increase but will drop back to 2.6 when release gas pedal then goes back to 2.8. I never change the fuel filter after I bought this car(9 months old). By the way, if I change the fuel filter, is it required for remap ecu?
Add in additional info of my problem. Got fuel smell come out from exhaust, is it fuel running rich or lean? sometime can see carbon(like burned paper) come out too......
---------- Post added at 01:46 AM ---------- 6 hour anti-bump limit - Previous post was at 01:42 AM ----------
hye.. i'm having kinda prob b4, same the fuel pump sound weird, u can hear it inside ur car.. car oso stalling.. the fuel regulator gauge playing from 2-5.5... try this n try that.. finally only my fuel regulator kaput.. now change to SARD and car back to normal.. just want to share~
Thank you so much bro for sharing. But my Sard fuel regulator just changed not long ago.... I changed it at Jan 2010.
