stock rims tyre
mokh
hi all,
the standard tyre size for our stock rims is 215/45/17 right? how about if i put in 225/45/17. if there any much different in handling, looks, etc?
please advice..:hmmmm:
of course with wider footprints you will get better road surface contact n ..thus handling.
however, there will probably be minor higher fuel consumption...dunno how much
plus, since the tires are wider on the stock oem rims...the stock oem rims are 17" x 7j in width. the tires side walls will jut out a bit.
btw for the uninitiated...7j means the rims are 7 inches in width 8j = 8 inches width
i would say go for it coz the tires 215 or 225 pricing would not be too much of a difference..unless one cant afford to pay that little extra
hi all,
Go do a google and search for a "tyre bible"....then you can get optimum fitting for your rims.
Irrespective of what tyre you use dont forget your suspension,alignment toe and camber.
talking about camber, is anybody here running with negative(-) camber ?
if yes, how many minor degrees ?
yaya..., i kno other than neutral (0 degree), tyre wear is compensated in some sense...
:adore:
learned a lot from the site. tqvm.
btw, i cant find altezza stock rims spec. can somebody post it here please
dear taiko, correct me if i am wrong,
should be 17 x 7j, offset +50.
7j shud be able to handle width of 215 and 225.
7J means 7 inch width approximate 175mm....yeah you can put 225 or even 235 depending on what series but its not 'optimum'
too wide and speedo accuracy will be affected, though marginally
http://www.tiresizecalculator.info/
i think my speedo is under over reading. paired it with my GPS before shows -10km different esp on 130km/h and above.
wfhan,
no lah..just learning about tyres. :driver:
//correction.
u mean your gps showing higher speed, and your speedo showing lower speed ?
mine is opposite..
for example.
gps show 90km/h, but speedo shows 105km/h....
i'm on 215/45/17 front & rears..
ops..sorry. its should be over reading. same like yours.
current tyres setup also same.
i think altezza speedo is over-rated.
is either you accept the (over-rated)reading or you send for calibration.. ** i donno where to do calibration also...**
Hi there, need some advice from all sifu, our Altezza can clear rim size 17' front 8 1/2' off 30, rear 9 1/2' off 40 ?
Hello u wanna put 265 tire behind is it. Crazy
Front max clearance
17"x8j with +38 or +42 this will be inside wheel arches
offset30 with 8 1/2 rim will come out of the fender. Unless u dun mind la
Rear max clearance
17"x9j with +40 or +44 this will be inside as well but u probably rub the inner arches unless they are 'rolled in'
Rear 9 1/2will also come out la.
A little out is fine..too much n u will look like a four wheel drive.
Put in the wheels n see first
