aiming 1.8 boost..advice pls..
qj3
hi guys,
if i were to aim 1.8 boost on my l2 engine, what kind of additional injector do i need..240cc?..390cc..? n how many injector need to add? one only?..
normally which part on the intake manifold that injector will be place?..thnx in adv..
from my exp, tried twice,
1st time break the turbine, nvm... cos old ori turbine dy... engine still healthy..
2nd time, hits the 1.8, speed bout 18Xkph, chasing Estima... once reach 1.8, turbine break into 2, 5th gear oso broken... but the engine still healthy till now...
now the 3rd time still in pending mode... ha...:stupid:
yours stock internal ah???very tahan....
p/s:my friend back then even 1.5bar already chopped his vf4 on L2....turbine putus.....huhuhhu.....
now im using rhf4 turbine with stock engine,boost at 1.3bar,top speed 17+km/h,the engine still in good condition...but can i go to 1.8 bar??any one can gv some advice??
yup, all stock... only clutch not stock...
everything oso can't tahan, but only engine can...
like gb, only reverse gear haven't break yet... still survive very well.. hahaha
jineol...then u shud try racing with other using reverse gear...just like brian did with his evo7 in 2F2F movie...haha
bro,what brand u use for clutch??3spoke?
1st time using 3 puck, but can't tahan long... now trinity...
hahahaha.... then must change to land rover gear box that hav 2 or 3 reverse gear only can loo...:biggrin:
yeah i am aware of the needed mod b4 go to that boost or higher.i have done general overhaul new main bearing,con rod bearing,thrust washer. using l2 carb turbo piston ppl call it piston kepala hitam ( i heard this piston can boost up to 2 bar without sweat..true izit?), metal gasket, head port n polish, grind valve, new valve seal.
n i knew the fuel management must be upgraded too like fuel regulator, bigger fuel pump, air/fuel mngment system n also extra injector.
jineil2en :
wahh 1.8 bar ?? r u using xtra injector ? where do u place it ? try td04-09 from subaru sti,this one can boost up to 1.8 even there's ppl try 2.0 bar.there's oso td04l turbine from pajero diesel, but cannot lawan from subaru one. when ur last time boost up to 1.8, fuel pump oso stock ar? what bout ur fuel mngment..share la fren..
---------- Post added at 08:41 PM ---------- 6 hour anti-bump limit - Previous post was at 08:36 PM ----------
owh...i see....
bro, lets try up boost 2gether ha ha..
yes bro....the highesthp for kancil tested dyno at gt auto is 270hp....hehehe....
we can do ma.....money is always the issue....hehehe
270hp ? must be with nos rite..got otai extreme mod using garret ar72..185hp at 1.8 bar n 215hp bar at 2.0 bar..then after nos came in..hp jump to 280++..but then injector jammed..imagine what bar that time..more than 3 bar..gila wei..jantungku cannot tahan g-force..
he oso using 850 blok + 660 mid piston..
nsdrag double spring clutch cover oso good...huhuhu..
just its quite hard..great for drag i reckon..
