Hi guys... New cars with low-pressure turbo (LPT) especially the european ones have ever increasingly fuel efficiency and economy. They don't give much high end power compared to high-pressure turbos, but surely loads of low end torque for strong low to mid range acceleration, which is... quite fun. The principle is simple, more torque allows you to accelerate to the cruising speed faster and thus it reaches the higher gears faster. More torque also enables taller gearing.
Now the question is... Is there anybody who did a bolt-on turbo (BOT) / self-modified turbo to their stock NA car and achieve similar result (improved fuel economy)? Please share on the type, settings, location or anything info.
---------- Post added at 02:37 AM ---------- 6 hour anti-bump limit - Previous post was at 02:33 AM ----------
Usually, BOT engines are more thirsty due to the ECU that is not originally designed for boost. Improved economy is only gained if the car have early boost around 1.5k rpms and maximum vacuum while cruising. Maximum vacuum when cruising is the most important for good FC. Most BOT do not have an engine management/piggyback that can release boost to create vacuum for economical cruising. Even is the throttle is almost closed during cruising, there is still a certain degree of boost that exist. So BOT generally have worse FC. Now the question is... Is there such a boost controller/engine management/piggyback unit that can help to release the boost when the car is cruising? Can a systems sense that a car is cruising and not accelerating and thus opens the wastegate to prevent boosting? If there is such a system, better FC from BOT can be achieved!
Please share!
Please share!
