automatic gear blinking at 'd' and the engine symbol appear..
paje
hello guys,
i got some problem with my neo, i used to buy 2nd hand neo..
while i driving (1.6 AT) my gear "D" is blinking..
then i try to stop to cool down my engine..i thought my engine is overheat..
coz it appear my sign engine (orange colour)..then when i start again my driving..when i shift to "D" gear it start blinking...i try to shift "3" or "2" it wont change..it remain "D" blinking...
whats dat problem...my mileage about 76xxx..
have you send it to your foreman to inspect it? if not..i think you should...
Any recommended gear box specialist ?
My wira 1.5A have gear box problem lately, foreman claimed gear box faulty cost Rm1200 (kereta potong)
if only light blinking nothing one lar...so far ur gear box can shift gear normal or not? if normal it is ok one lar...
ur gearbox has gone into safe mode , the car computer detects something wrong either ur gearbox oil is bad or gearbox overheating, goa nd check before ur gearbox spoil.
And another to brother bon bon , where u live , if u free i suggest u go take a drive at ukay perdana entrance in ampang , from the highway u cut into ukay perdana towards sering ukay, there is a sign on the road by gearbox specialist , repair gearbox is rm 650 for wira 1.5 at. go check
yup, it's in 'safe mode', u need to "reinstall" it.. could cause by hardware prob..
hahahha :banghead: juskidding....
my sister just bought a 2nd hand iswara 1.5. the transmission is auto. i sense something that's not right because the gear is late when shifting. according to a friend, it was caused by the clutch plate. the car also not very strong when climbing the hill, like the power wasn't there......
hello guys,
Try to check your Engine Oil, Whether the level of the oil is sufficient and also check your ATF Fluid. If its lower than the line, check if there are any leaks in your garage where you park your car...
Before you check ATF Fluid, start your engine until your car warms up at a appropriate level. Step on the brake and start shifting your gear all the way from P to L and L to P again...after that pop up your hood with the engine running and then check your ATF Fluid level. Is more accurate to check ATF fluid this way from what I learned
Still if not below the line and no leaks, better send it for a check.
When you are driving at higher speed, try manually downshift the gear, you should feel the wheel dragging from highest gear to the next lower gear, keep slowing down and shifting until the lowest gear, if in between you don't feel the gear shift at that particular gear that means it's not on that gear, e.g. if you shift from 5th to 4th gear but it doesn't shift, it probably stucked on 4th gear (can't upshift till 5th gear). If that is the problem there's a small part needs to be replaced, cost hundred over.
Had this problem on my car. It's a different make tho. I had to change some solenoid thingy at the gearbox. Couple of hundred to fix and reset the error.
