DIY on cars?? post in your Q?
hanslin
:biggrin: :itsme: i'll give my idea n advise base on what i know so!
pls forgive me if i were delay to reply,wrong and correct me!
:biggrin:i will choose to reply or not! based on question that will bring side effect to workshop!:biggrin:
other sifu are welcome to joint in, TQ
So what u waiting for? QUESTION ME!!!
wah.. can ask any question on how DIY things ar?
can guide me how to change the auto gear knob for waja? with pics perhaps? thanx.
:itsme: u are the 1st:dancing2:
Pls note what gear nob u going to install?
std to std different spec or after-market!
Pls prepare the tooling before start working!
std to std :(+) screw driver, make it is proper size!
std to after-market :(+) screw driver, make it is proper size!
: refer to the new gear nob.
Remember the step while disasemble, were it need to reverse the step!
std to std, step:1. There are two screw behind the nob, its facing dashboard!
2. Remove both screw with one hand holding the nob.
3. Slowly lift the nob upward, remember the part and spring location!
4. Ready the new nob and transfer the missing part if they were!
5. Reverse the step from 3 to 1
6. Test the unlock button from P to R than R to D
I dont know the look on your gear nob, pls send some picture!
std to after-market : 1: Follow the step on top!
2: If the nob have 3 screw(3-5mm) at the bottom they should be tighten evenly
Pls ask more question if u feel not confident enough!
U are welcome to share your picture on your work!
Good luck!
:biggrin:other sifu are welcome to joint in, TQ:nurse:
go ahead!
just remember the safety part!
hahaha... ok.. tq 4 da chance. but to tell the truth, i dont know how to do it. what i know is we need to have a tool that hold the spring before we remove it. thats it. sorry... haha.. (what could u expect from a 5bhp stock afterall?) hehe... so sorry liow....:adore:
Hi bro...!
Want to ask about VTEC lamp...?
FYI... my car Accord SV4 95 H22a siR..!
TQ
:itsme:hmm.... u might choose to go workshop after u read this!
The thing Ray mean is on the picture!:nurse:
Tool that needed:
1- car jack, but the safe is to use a 1-2ton jack! where the jack behind the car is to lift up 1 side only!
2- 2 unit of car stand, were is use to secure the on the height u need.(dont try using wood or brick, slip in the spare tyre under if u going for it)
3- 1 pair of spring holder.(see pic)
4- tool to remove wheel and absorber:
1/2" auto handle
1/2" L handle
1/2" extension (12")
1/2" 21mm socket
1/2" 19mm (long)socket
1/2" 17mm (long)socket
1/2-2kg hammer
19mm/17mm double ring spaner
12mm spaner
Allen key set (metric)
grip plier
cost to buy tool rm200-300 or go workshop and paid rm20-50 for it to be done!
:biggrin::nurse:if u have 1/2"impact gun, it will make ur life alot easier!
:nurse: if u still want to learn, pls reply!:wavey:
whoaaa.... detail like this can open collage already bro....
*wheredo i sign up...
Hi bro...!
TQ
:itsme: can i ask, about your question about VTEC lamp...?:confused:
vtec model head lamp and the std model?
vtec is the one with black base!:nurse:
:biggrin:if not pls give more detail about what u want to know?:biggrin:
walawey... this bro hanslin really generous to help ppl 1.... :adore:
mind to pm me the address of ur shop? coz last time i ask acc n spare part shop they ask 4 RM60 as labor fee to install 4pc of abs+springs.
Bro..I bought air fuel ratio gauge...n i owned persona campro iafm...i hope u can help me on installing dis gauge...i dont know where to tap da o2 sensor wire at campro iafm ecu..i wish i have da ecu wiring diagram...can u help me bro..???with some pics..??diagram..??? i went to so many accessories shop n workshop at my place but no one know how to to tap the wire...if anyone here had experience installing apexi auto timer, please help me..i shud be da same wire for o2 sensor...thanks
hanslin, hope u dont mind i try to respond to this question, rite.
admehdivkia, it 2 ways where to tap that wire.
1- as u said, tap it to ecu o2 sensor wire (this step not many people to dare with it.
2- tap it to o2 wire in ur engine bay (this step is less risk). how to recognise it? u can see it from engine bay, something like spark plug attach at ur exhaust. i dont know exactly where it is unless i look at ur engine bay. as my 4g93t, the wire look like this:
when u already find it i will continue, all u need after this, multimeter, insulation tape (for cheapest method) and maybe 1 -2 mtr wire to connect it from ur gauge to o2 sensor in engine bay.:biggrin:
