Mods for 4g93p pls help me ! Thx !! :)
get a lighten crank pulley,racing clutch...lighten your flywheel get a port polished head..if got budget why not mix and match with mivec head...pistons...upgrade fuel pump...get a fuel pressure regulator..
Wait .,....your 4g93p using MMC or Siemens ECU ???
how bout siemens? cannot mod at all?
4g93 na or +turbo....all is on ur mechanic setting,here i just suggest &share..
+high cam+adj cam pulley
+clucth racing
+fuel regulator
+crank 2.0- play stroker
+pston 82m for BOT pston s.charge trd 82.1m
+injector-depend ur mechanic setting
+port polish head-Metal gasket
+pum need bigger etc walbro-depend ur mechanic.
+t.body 2.0 prdana
+ecu etc-emnge(piggybck) better stand alone much better
+do cam timing!!...
See de result..think ur car can join de drag race.....can pm me 4 futher info..
i already do R&D to engine 4g93/T can beat evo machine...
if you are going for extreme mod...beter not...
if you wanna play properly or all out ...better convert to MMC ecu..
if you just want a bit more power...then you can modify a few things...like exhaust,filter and all...but cant get piggyback ecu and do tuning....your ecu will reset its self...
u mean extractor & air filter? what other thing can mod for siemens?
u look for sifu 93na, he is 4G93 na sifu...
he did alot of mods to his car as well....
did anybody mention about handling ??
all about powwahhh
spent to suspension...tyre...and brake oso la
power without control is nothing.....my grandpa said:biggrin:
