speed cut.
lord how much is the unichip thingi.? plug and play or need some modification.?
dyno before install...installation process...dyno after install plus tuning....all together is rm2k..
i do it at RS Impressive pusat bandar puchong...meet d tuner name Robin.
the piggy back unichip can be tuned up as well.? isit tuned for the speed above 180kmh.? cause as i know rsm can remove speed cut as well but not good cause original ecu still detects our speed at 170kmh, so the fuel, air intake and stuff all does not fit the speed that we are driving when we are above 180kmh. correct me if i'm wrong.
this is wat ppl say....but so far i have no problem with it...good until now.. :biggrin:
So wait - if Jap spec Zeds have speedometers that are limited to 180 km/h, how do you know what speed you are going at once you've gone past that threshold? And will the digital speed readout gauge show speeds above 180?
For example, my Zed being an Australian spec car would be able to show the speed above 180 since the speedo stops at 260 km/h.
http://img97.imageshack.us/img97/2486/img00198200911042209.jpg
:confused:
:confused:
d speedo continue at d digital gauge...it show ur speed even above 200kmh...but mine..i change to Nismo speedometer..d reading is up to 300kmh.. :biggrin:
p/s: wow..this is 1st time i see Z australian spec speedometer..n urs is rev version..
Ahhh, makes sense now :biggrin:. Was trying to get my head around the image of the speedo needle straining at the limits!
I was studying / working in Melbourne, Australia for about 7 years before the car was brought back on a student AP.
i think can read above 180kmh. i reach 188kmh then i continue stepping on my gas and my gas got cut due to my speedcut.
btw lord, how does the piggyback unichip works.? what is the tuned up for.?
it works gr8 as i mention earlier...it increase d hp up to 18horses..piggyback all works d same..d tuning is to make ur throttle more respond..tune for better air n fuel ratio...n lots more which i also forgot edi. :biggrin:
thanks lord. that's wat i wanted. i dont wana touch my original ecu, as i dont want anything bad to happend and kaboom my engine lol
Mine's with Unichip. So far, response has been good after tuning.
Oh...Many ppl use Unichip at here...I think Unichip should be no problem since u guys using it with no problem...^^...
btw lord, can tell me the brand of your piggyback unichip you using.?
Unichip is d product name n got several version...its from Dastek. Mine is Unichip Q a bit more advance compare to previous version of unichip.
ohh okay thanks. the unichip is use able for any transmission rite.?
