195/50/15 vs 195/55/15 for vios... pros n cons?
am using 195/55/15 for my gf's vios.
pros: corners slightly better (wider track), slightly less bumpier (thicker sidewall), protect rims better, gives a more secure feeling
cons: speedometer reading is off by a very minimal amount (barely noticable) due to bigger circumference
by right , 50 corner better.
BUT,it also comes down to owners preference.
some ppl feel more comfortable with 50,some 55,like my self also i "feel" that 55 corners better.
You can refer to this thread 195/55/15 or 195/50/15 some good points there
The tires (55) are taller with the replacement. Also speedo would show slower speed. You will not corner better. But there would probably be no different in handling. There might be slight increase in tire weight. So the steering would be very lightly heavier or no difference. But you will gain comfort as the higher sidewalls allow more travel in /damping compressing weight.
Again 195 is the width of the tire, 55 is the height of the sidewalls and 15 is the wheel size. Its very logical markings. I do not think a 55 tire would gain cornering advantage over a 50 one. Simply because the flexing of the sidewalls are more for a 55 one. So you get a wobbly response. But because 50 to 55 is not very much in difference, its hardly noticable. If you get a 60 or 70 one now that would change a lot. But the tire size would change too.
yeah... you are right... 195/55/15, 195 is the width of tire, but 55 is calculate like this... 195*55%=height of sidewall... means Weight * x % = height of sidewall. Example: 175/50/15, 175 is width, 50 is 175*50% = Height...
same track width la . thinner side wall.. harsher ride. better handling that all. nothing compllicated
i think he means compared to std vios lah.. std only using 185/60/15
but if the rim diameter is same,but the tire is thicker, the rotational speed of the wheel will be less for the same car speed. so, it will give some advantage to the handling if use thicker sidewall..the speedo reading will be affected also..
my brother vios speedometer does not accurate if compared with GPS reading
the speedo shows 100km/h but the GPS shows only 91km/h
the car use 16" rim rim tire dimension of 205/45/16
crazy thin sidewall and crazy low profile tyre dont help handling.. but 195/50/15 still doenst fall under that category.
55/15 profile consider thick lo for performance driving. kills handling. high speed stability and cornering grip sure lesser.especially with ordinary tyre. only if u r using performance tyre with thick sidewall like ad07 then its another story. sidewall flex around with 195/55/15 , using man power to push ur car while its park from side to side already can see the tyre flexing. what more if u drive it harshly. im running on coilover suspension. with 195/55/15 go over pothole also merely felt anything. when change to lower profile tyre running with 16'' , go over pothole feel like breaking my vertebrate. but high speed grip and stability is no match with lower profile tyre ..
Low profile tires does not mean lesser handling. Its all in the compound and thread pattern. But so much variables to determine if the tires are good or not.
Width, height, rebound, thread design, wire, compound, blah blah. The best attributes simply means more money. hahaha.
Oh yeah to correct my last words on speedometer, its faster not slower.
I have one of the issue using 195 55 15(my02).. when is on highspeed 110km/h n above.. my ride feel like a snake...
I dono whether u guys get what i mean or not ??
is like i have to pull back the rear to straight line.
driving vios07
I hope u guys can gv solutions ?
thanks !
driving vios07
thanks !
MY01 and MY02 tyres are rubbish. 55 profile is a little high and MYxx tyres are soft sidewall. So looks like it might be soft sidewall?
I recommend Federeal RSR 205/50/15. Super hard sidewall and the height of the tyre looks like 55 even though it's 50. Wider track and awesome grip.
hi bro IZSO,
wanna to tumpang a thread ya.. spec tires 205/50/15 is not a rare tire spec? how much u get this tires?as what i know, this is very rare spec and also pricely is it true? this is only my 2cent knowledge.
hi bro IZSO,
Yup, this tyre size is less common and more costly.
---------- Post added at 08:27 PM ---------- 6 hour anti-bump limit - Previous post was at 08:27 PM ----------
You kena poison liao.....hahahahaha:rofl:
hi bro IZSO,
So far I've only heard the AD08 Neova Yokos and Federal RSR have this size. I bought my RSR for RM260 a piece I think... it's about the same price as the Michelin PS3 or cheaper. So you say expensive, not really la.
federal RSR memang grip, BUT, it has problem mention below,
1) sidewall easy crack if u pump <32psi, if > or =32psi, =u feel bumpy.
2) some tyre surface got crack line, mayb it wont KABOOM, but u will not feel save to use it.
3) due to the tyre "BUNGA" pattern, u will feel like ur car r very sensitif to the road condition, if the road not really flat n smooth, ur car will move left right like alignment dah lari.
4) 205/50/15, u feel like heavy, car acceleration feel harder drop, n top speed drop too.
5) when cornering, u feel save, but not flexible, respond bit slow.
just my share my xperience n feel.
Hmm.. I just changed to the RSR before the ZTH TTA and have been on it daily. So far haven't experienced any cracking. I always keep my pressure above 220kpa (32psi) so that's not a problem for me. I don't have any issues with bumpy since this is a performance tyre, some level of discomfort is acceptable for the way I drive. :biggrin:
205/50/15 heavy meh? Nothing has changed for my acceleration and top speed. Maybe it's the way your car is setup? Slow response in the corners? I'm not sure you mean. During Sepang it worked quite well for my car. Perhaps your car too power la
But I have to agree that the tyre will follow the road since the thread pattern is v-shaped. I'm already used to the twitchy handling with the chassis alignment kit I have anyway. No issues, no complaints.
For the price I paid for the RSR, nothing in the same price range offers better driveability!
