SAGA BLM Project Hideout
mysayasan
Johor Bahru
Welcome all! In this thread we can discuss anything about modifying ur saga.
Ok for starters. I really want to ask sifus out there, does campro 1.6 piston or conrod, can fit into 1.3 block. Cause of what ive heard, their bore is the same, just their stroke is different.
What ive done to my saga:-
1. Change super touring pressure plate. Need to lay so can fit the new clutch plate.
2. Bonnet got lamp now. First batch BLM B-line dont have bonnet light.
3. Auto lock when step on brake.
walao... this 1 real hardcore.. turbo somemore... this mivec aR?.... if want to put campro 1.6 block can ma.. but dun want put block.. just play with conrod and piston.. will have problem?.. i just want play with campro engine only.. if got 15k above sure i put mivec MD in my bonnet
---------- Post added at 10:47 AM ---------- Previous post was at 10:45 AM ----------
forgot update
4. Exhaust system
5. Air intake.
if wanna change to 1.6, change the con rod, piston, head, all above part engine...
but i think it not adviseable, coz 1.3 hole gap is to small, afraid will crack...
try use open pod, change extractor,
but happy mod:biggrin:
1.3 and 1.6 piston size is same..just 1.3 is slight dome type....while 1.6 bowl type piston...
different is crank stroke dimension and conrod if not mistaken... :adore:
so that means we can restroke the 1.3 to 1.6 by using the crankshaft and the conrod and using back the 1.3 piston which will give a higher compression with bigger displacement right?...then source for cps head and wiring lor....sure got some nerve to play2 around with neo cps hahaha..
don't forget to install lcp,pz extractor,adj fuel regulator, and cold air intake....:p
---------- Post added at 10:42 AM ---------- 6 hour anti-bump limit - Previous post was at 10:39 AM ----------
i have a 1.3 blm auto and to my surprise, even after instaling micro air compressor to tune the a/f ratio a bit, it felt much better and pickup can play2 with myvi hehehe...wonder what could happen if restroke plus cps stuff and IHE mods, sure can hit 200kmj easily with std 14" rims
You can hit 180~200 km/h or maybe more (with upgrade of course)..just the body wont coop well...that all
