The best security for your car!!!
what about we customize 1 sticker.
"Protected by CAPTOR"
:D :D at least they will think twice and prolly move on to the 2nd car
once ur ride become target, thief ll find a good chance to stole. chain, streering lock gear lock..bla bla... not use. better get a immobilezer, once the thief cant start ur engine, they ll kelam-kabut n run away.
HI GUys,
Does anyone know how the thieves still get away with cars that have immobiliser? do they just tow them away? or do you think they have a way to restart the car?
HI GUys,
Several of the immo got bypass... so they use that method... bypass the immo...
if they can't drive away the car, they will take the parts... :banghead::banghead:
Does secret fuel cut off switch really works in preventing those thieves taking our cars? Anybody have experience installing them?.. Im thinking of making one
u can install another alarm unit to control fuel cut. control by using remote control.
install a normal alarm system. using the alarm active ground(-) signal output(grey wire) to connect to a relay. using a relay to turn ground(-) output to positive output(+). connect tis output(+) to original fuel pump relay wire.
went alarm is activate, fuel pump is active too. wen wen alarm is deactivate, pump is not in function.using LED as indicator.
like tis u car can be start, but is ll be jerk n shut down in 1 min. thief ll be panic n run away. cost ll be under 150.
Write your reply...
New Posts
