U got a point also ....the owner car the owner money and also the owner wish what he want to do to his car and where he want to do it ....
Burn-out outside pubs like Krave??? Must be trying so hard to impress that two hostesses ... Suddenly skyline's in Ipoh just turned Ah Beng car ...![]()
i wonder, for stock GTT, what's the max speed after removing the speed cut? Anyone tried it before? Care to share?
BH, I really don't know what's it that with you ... So, I guess you like to run thru all my postings on what I said and what I think? No doubt what they do with their money is nothing of concern, but then again, what I think is nothing of your concern too. Look, BH let's not make it personal here. And by the way, what makes you think I have an RB26 or whatever.
And on the last statement about big turbo and everything, admittingly I am probably so shallow that I have no idea where you are coming at.
eyong said:And by the way, what makes you think I have an RB26 or whatever.
eyong said:Quote:
Originally Posted by speedy3210 http://images.zerotohundred.com/images/easyblue/buttons/viewpost.gif
*SHELL ron 95
1. Mileage: BAD
2. Power: MUCH WORST
3. Engine knock: SLIGHTLY
4. Engine's idle and sound: ROUGH
5. Starting: NORMAL
6. Damage or symptom that occurred or happen after you tried Ron95: SO FAR, NOT YET
That's a good template, speedy3210
Petronas ron 95
1. Mileage: N/A
2. Power: LESS and MISFIRE AT LOW RPM
3. Engine knock: N/A
5. Starting: NORMAL
6. Damage or symptom that occurred or happen after you tried Ron95: KEEPING LIGHT ON THE PEDAL - HAD TO USE OCTANE BOOSTER
7. Engine Type: RB26
eyong (in one of his many non-ahbeng quotes) said:No, I don't take offence for constructive comments at all. In fact, I do appreciate the info very much.
eyong said:Must have hit a soft-spot somewhere ...![]()
Bout 255km/hr
Bout 255km/hr
MJ, how do you increase top speed? Is it by adding bigger turbo, therefore bigger HP, ergo higher top speed?
bigger turbo, higher rev limit, lesser weight...
I bet this car could do 340 KPH
just like this dude did...i THINK the car in the vid has a T51R... and this local R34 has an even bigger turbine
oh shit. then i must start jogging everyday... :)
:wavey:
