Yay or Nay? Evo 6 convert
DRFT_240sx
Hi all ,
Would like to buy a weekend track toy , and am contemplating to source for a evo 6 convert.
Since I do not have any experience or knowledge behind getting a convert would like to know the advise of veterans here about buying 1 for sepang track driving.
Thanks a lot all
18 pages long thread , do u know of a specific post bro?
---------- Post added at 01:28 AM ---------- Previous post was at 01:23 AM ----------
correction: filter the entire thread no info on converts at all
anyone care to chime?
Opss...Sorry...wrong info....Here is the 1....
Some info to start on Lancer n evo chasis codes.
96-99 Lancers chasis codes:
CK2A-SNJA/SRJA - MX normal 1.5/1.3 (2WD FF)
CK2A-SNXM/SRUA - Lancer MX Saloon 1.5 (2WD FF)
CK2A-SRPM/SNPM - Lancer MX touring (2WD FF)
CM2A-SNXM - MX Saloon 1.5 (4WD)
CM5A-SRXM - MX Saloon GSR 1.8turbo (4WD)
96-05 Lancer evolution chasis code:
CN9A - Evolution IV
CP9A - Evolution V,VI (and TME)
CT9A - Evolution VII,VIII,IX
As you are interested in conversion yourself, here some question you should ponder and my answer to it. At least
you know it Before hand than later which is too late once you've decided !
(1) If a lancer convert to evo, is it legal?
If chasis structure is modified, as in cut and reweld, than is illegal. As long as engine mounting point are not modified, over CC conversion can still be accepted. However do take note that to convert fully to 4wd from 2Wd will cost you some difficulty initialy with JPJ unless you manage to source a 4WD chasis lancer.
For conversion wise, I would suggest you source for a 4WD lancer but from experience, is very rare to get CM2A and CM5A(rare) lancers as they are original 4WD hence expensive for a 1.5 saloon and not sought after. For 2WD chasis, they can kacau lar if u convert to 4WD. Ask u to go inspection lar..dismantle lar..bla.bla..bla.
However as we all aware, this is 'boleh land' lar..if u got the correct face printer on that paper, can
always work out something lor. Get my drift.....?
(2) can 1.3/1.5 to 2.0cc pass JPJ inspection?
Read my lips ! "Money makes wonders !" However, nowdays because of the change in JPJ top guy..It is VERY and SUPER difficult to approve over cc engine conversion and transplant especialy when it involves conversion from 2WD to 4WD.
One of our fellow forummer in MLOC has recently 'experienced' this difficulty...LoL
(3) How do you convert safely and from 2WD to 4Wd ?
Chasis:
This is the most important part assuming you perform a full convert of wiring, engine, gearbox and kits. Harden
your chasis especialy the ENGINE HOLDING bays and the Mounting point hold ! 2nd to that, is the connecting chasis
inside your car and some portion of the fuel tank hold. This is very important as lancer chasis are not made to
withstand the 280ps and the G-force 4G63T evo engine generates ! If this is not possible or you do not intend to drive long or with full power then it's ok. Otherwise you got to be very careful with the way you accelerate and not to push to hard on the car or you'll result in tearing the chasis joint especialy on the engine mounting area in the engine bay. If it's possible, remember to use Argon weld (non rust and very solid) and not those al-cheapo steel weld !
example of a join..
lancer:
evo:
so to hardened, you weld:
---o---|---o---|---o---|---o---|
Get my point ?
As for 4WD:
For Lancer CK2A (2WD), you need to cut the rear but for CM2A (4WD), you can cut or not to (by modifying, but less safe) the mentioned.
Conclusion::
Is very troublesome to start the conversion on your own as your car might end up months in a garage and again as I've mentioned earlier, you need to restrenghten your chasis especialy the engine bay if you intend to convert safely from a lancers and evo and all the spray paint jobs. I'm stressing this as I am very concern and particular with a safety of the car handling such power. I've also shared this as an experience as myself and a few of my mechanice frens did experiment by tearing apart a evo full cuts chasis and compared it with a totaly striped out Lancers. The only difference in chasis we observed is the closer and higher number of weld point on a single fold/join compared to lancers (as above), the X bar on the rear portion of the seats cushion (visible from the boot), and the glass material used for the windscreen and windows. Evo's window/screen are lighter and slimmer.
If you are getting a converted evo (and save the job of getting a lancers, a good half-cut and convert thereafter) remember the following values do count into consideration in concluding the ultimate...price.
- Year of car (IMPORTANT on your loan portion)
- Accident (of course lah)
- Conversion approval (Puspakom, JPJ papers, car log stamped)
- Chasis (2WD or 4WD lancers - legality and if you don't mind a 2-4WD, to negotiate price lar) ?
- Conversion type (Rojak 4+5+6 engine parts, or proper full cut convert)
- Interior (You will be suprise how expensive it's interior are and how difficult to source one when needed).
- Safety (Chasis hardening, etc)
- Bodykits (yes..fibres and originals differens a lot in terms of quality, price and more importantly, safety. Again, if you drive like aunty, then forget about the safety part or else, a fibre bonnet is like a spring bomb in front of you waiting to jump on your windescreen as some of our member experienced the hardway!).
- others..wheels, type of rims, after markets parts (evo parts cost bombs especialy ecu n clutches,) condition of cars and parts..use some common sense lor.
My opinion:
Of course, if you have the extra cash..is always a good choice to get an original evo ! For me, if I get an ori, I will be left with no 'extra' for mod...so instead of driving a original evo stock...I got a converted and use the 'extra' for mod coz I can't control my 'itchy hand'...hehe.
If you are interested, do join our MLOC (Mitsu Lancer owners club) TT in KL or read further in the MLOC tread. We have lancers and converted evos as well as ori evo in our TT and I can share with you in more details.
Hope this helps. Happy venturing and welcome in advance to the family of mitsubishi !
as long as you keep it as a track car and don't drive it on public roads, you can modify/convert it whichever way you want to. if you wish to drive it on the road, then 2WD to 4WD conversion is a big gamble. even if you can "getaway" with the initial inspection, there is no guarantee that you can "getaway" from future inspections - its a neverending risk. good luck with your project :)
thanks a lot
anyone know the history of this evo 6 convert?
http://www.mudah.my/Lancer-convert-evo-6-3612642.htm
Bro,
If you really goin for track only then might as well you get a evo track car that cost half the price.
But if you wanna whack on the road once awhile also then no problem getting a converted evo.
bro...
better find ori evo 4wd.....casis more heavy duty ...wakekekeke:rofl::rofl::rofl:
thanks a lot for your feedback guys?
So no one knows about the car i posted above?
I would like to be able to drive around sometimes * itchy legs* want to go bkt tinggit or ulu yam kekeke.
But for a convert , if weld a roll cage , will it still be a problem?
anyone with personal experience?
No money to afford the real deal just for weekend car =\
As far as I know, if u fit a roll cage, then it is not allowed to be driven as a street car/daily driver in Malaysia. One of the forums has discussed this before.
true , but will it address the problem of chassis rigidity that everyone is mentioning?
not really.a roll cage is more towards safety of the driver in case the car rolls over.cause a normal car roof offers little protection to the driver.chassis rigidity could be addressed by fitting strut bars and other form of support bars.but this add weight to the car.
budget 70k . buying full cash.
so anymore other worries of a converted evo?
One thing u must know about Converted Evo from Lancer CK is that if u never convert 4WD your ride will have tons of trouble later on. Unless your ride is a stock and never plan to mod much coz I hear tons of scary stories with powerfull FF cars running like snake on the road.
For 70K Cash budget Why dont go for Evo 7 or higher, go for loan, pay higher deposit then pay less installment per month. Less trouble coz it's a newer car, less worry coz it's not converted, and less "IF" later on.
But if you are keen on the Evo 4-6 look and dont mind fixin up probs and this Evo will be your 2nd or 3rd car then by all means take your time slowly hunt for one. One thing I would suggest is try to hunt for an Ori Lancer CK or CM then do the conversion your own. At least when converting you know what u have done instead of lettin others do the dirty deed. :rofl:
yup , 70k cash is definately enough for a converted evo. as what i know now most of the converted evo is 96/XX or 97/XX, cannot get loan already.
I might consider to let go mine's, but i'm from JOHOR , if u're interested can PM/SMS me to discuss..
buy an Ori CK or CM then do conversion by own? if someone had converted the CK or CM to EVO sure know how much they pay , mod + car = now almost can buy an ori EVO , the parts still the same ex or maybe higher than b4 cos nowadays yen is increased.
if not wrong now if buy an evo 6 from chop shop still at least 20-30k i think..
Evo 4 halfcut lowest around 7.5k front only not complete. Evo 5 Complete Around 15k Evo 6 More to 20k. Depends your the one ordering direct or u go thru lots of runners. Convertion job usually 1 - 2k. Extra care to maintain your car like timing belt, clutch, turbo timers, meters, lets put it around 5K. Now most important is how much your gettin your Lancer CK or CM. Lowest I saw people SOLD is RM 35k. Average is 45K. Yes u can get Evo 4 Ori For 50-60K. Evo 5 65-70K And Evo 6 75-95K. But problem is due to the high demand and some buyers are really willing to pay much higher price, lower priced Ori Evo wont be around long b4 people snap it up. :rofl:
The "JOY" of converting on your own is u can see the whole process, if someone did it, probraly there's a reason they wanna let it go. But there's always a well converted and being offered at bargain price so just take your time to hunt your car. :driver:
