Change Wheel PCD
kezman
Hi guys,
I'm thinking of changing my wheel PCD from 114.3 to 100 but not sure if drilling my ride's original wheel hub using CNC machine or changing the knuckle itself is the way to go. Any suggestions? Thanks in advance.
But will drilling cause any crack to the hub? Ok I'll try and look for a PCD converter.
Hi newbie,can i check with you wats the pcd converter..i am interested to change my 5/100 to 5/114.3..saw the market place selling 390rm for a pair of 25mm converter.is it x??
---------- Post added at 05:15 AM ---------- Previous post was at 05:13 AM ----------
Using pcd converter u can change frm pcd100 to pcd114.3 or frm 114.3 to 100 without drilling or modify just pnp the pcd converter...
I'd done the hub drilling b4 with no problem.dont worry...
Ok thanks kelv. May I know where you do your hub drilling? I was talking to this Mr Tea from Hupshun Tyres in Sunway (same row with Everco) and he gave me some advice. Sounds like he knows his stuff though.
Previous i made at Lee brothers machining shop at sg besi...
is he strongly recommend not to do or ells, i also want to change my pcd 114.3 to 120....is there any shop can do that job in sunway?
