http://www.youtube.com/watch?v=UBNTWoPe8ycminta maaf bro :)
haha!!
ok..thankss !!![]()
watch this, then u understand
haha!!
ok..thankss !!![]()
hah no you know.. make King Jin angry.. how dare you..![]()
minta maaf bro :)
haha!!
ok..thankss !!![]()
Although dont understand what he saying...but i understand the action of wastegate !!
thankss !!![]()
small turbo boost 0.7 bar using big wastegate or small wastegate ?
what is the mm size suitable ?
and...
anyone low boost here 0.5~0.7bar using external wastegate ??
the dump pipe must use after using the external wastegate ??
how about internal wastegate? can use dump pipe too ?
hope can help !~
thankss !! 1 teh tarik for help
Theorethically, you should be using something bigger than 38mm... 44mm is better.
Theorethically, bigger sized wastegate is better for low boost wether ur turbo is big or small. But, bigger size wastegate is damn 97 expensive. So, u may think of getting the 38mm which are cheap and available everywhere...
Anyway, the effect won;t be so dramatic. There are tons of ppl boosting at 0.7bar with 38mm wastegate.
And boosting higher is going to materialize in your engine. It's the matter of time.
IF I can get 44mm wastegate with cheap .... that mean use 44mm wastegate better ??
:wavey:
use small turbo want hi boost use small waste gate,if want use bigger turbo hi boost also need small waste gate,if want use small turbo low boost need bigger waste gate,if bigger turbo want low boost need bigger waste gate......![]()
:wavey:
Wastegates - Facts and Fiction
http://www.turbosmartonline.com/images/2783.jpg
With so many contradicting opinions and recommendations, it’s a little wonder choosing the right Wastegate for your application can be a confusing.
We try to disspell some myths and shed some light on the most common misconceptions regarding wastegates.
TRUE OR FALSE
*The more powerful the engine, the bigger the
wastegate you need.*
False. This is one of the more popular misconceptions. A wastegate is possibly the only component in your whole engine package that can actually be made smaller as you increase your boost/horsepower output. Use this simple guide:
Big Turbo/Low Boost = Bigger Wastegate
Big Turbo/High Boost = Smaller Wastegate
Small Turbo/High Boost = Smaller Wastegate
Small Turbo/Low Boost = Bigger Wastegate
Wastegates don’t operate in high temperatures.
False. Contrary to the popular belief, external wastegates are usually mounted at the hottest part of the exhaust. It’s the place where all the exhaust gases meet, creating extra heat. This, combined with the late combustion of unburnt fuel (due to rich mixtures, retarded timing and high octane fuels) significantly raises the exhaust temperature.
Larger wastegate valve diameter = better flow.
True – sort of. While the valve diameter is without a doubt an important part of the flow rate, equally important, but often misunderstood, is the importance of the flow path. When comparing wastegates with similar valve size, it is important to have a balanced body/valve/spring combination that is designed to work together to allow for maximum boost control. All Turbosmart wastegates are designed with this in mind.
(*article courtesy of Turbosmart)![]()
Reading bout sex is bad for health on book then quit reading..haha...interesting...
---------- Post added at 08:19 AM ---------- Previous post was at 08:16 AM ----------
Just like hi boost small wgate low boost big wgate.
correct me if i'm wrong.![]()
. Anyway...
