Anyone using Ultimate Emanage ?
veilsideboyz
can give more infor about this ??
plan to changing my piggy to ultimate :)
i heard that ultimate emanage got two setting....
one setting is norma drive...
other drive is race mode drive ??:adore:
i using the e-manage ultimate now , yes! if have 2map for injector , 2map for ignition, 2map for acceleration injection n ignition, many more u can setting on ultimate
ur celica is auto or manual ??
can give me ur h/p number :)
wanna ask u something
Bump: ur celica is auto or manual ??
Any Sifu's to share abt the reliability or suitability of Emanage Ultimate onto Evo 4?
suitability - yes
reliability - okay okay if not going for full blown drag race
stability - nope
rpm extension is not stable, timing in datalog not really accurate.some bugs... u need to really understand this thing b4 you can diy tuning. for example. coolant temp compensation the unit need to be in Farenheit instead of celcius else it will mess up, the injector map if using large injector you need to use the unit in ms instead of duty cycle as emu had a lil trouble wid pulling out fuel in duty cycle form. when your car had knock, the stock ecu will pull timing resulting in your datalog showing negative value. even at idle your timing will be in negative. need to off the car to reset it. a lot to mention la.... when you play wid it you will know la... but i went thru everything and found solution for all the trouble i faced
