can 4g92p fit mivec throttle body?
wiramax
Hi zhtrian,
Need advice here.Can i install mivec throttle body to my 4g92p(1.6sohc) engine. FYI my car is with std 92p wiring & for 92p its use ISC throttle body whereby mivec t/b use stepper motor.I know if i change to 93 Dohc & mivec wiring it can be done, but it will be costly.Anyone has done this mode before?Hope u guys can share or advice.Thanks.
Hi zhtrian,
Need advice here.Can i install mivec throttle body to my 4g92p(1.6sohc) engine. FYI my car is with std 92p wiring & for 92p its use ISRC throttle body whereby mivec t/b use stepper motor.I know if i change to 93 Dohc & mivec wiring it can be done, but it will be costly.Anyone has done this mode before?Hope u guys can share or advice.Thanks.
i think u should see this picture.Maybe u can get the answer..
Clik this link
http://images.google.com.my/imgres?...rottle+body&ndsp=18&hl=en&sa=N&start=252&um=1
thx for the info mr lageenda.but that dsm throttle body, its from evo 3?coz its stated 4g63.
I think it should have any prob...
4G9x series can simply rojak everything but of course it doesn't increase much WHP unless u do proper tuning.
No matter it's evo or 93, as long as it been upgraded, it calc by size...
But my advice is u better select 4G93 than Mivec...
Coz mivec is use Mapping sensor where urs is air-flow sensor!!!
thx for the info.bt if i nt mistaken,93 std t/b is oni 54mm, n currently i m using perdana sei t/b which is 56mm.The reason y i choose mivec is bcoz their std t/b is 60mm.i m looking at option to chg to mivec t/b w/out changing the whole wiring to mivec wiring.But i do heard from frens dat it can be done.dats y i m seeking for anyone wo have done this mod before.
I think better u change the throttle body to the performance throttle body...
maybe u can't do this...w/o changing wiring!
ur idling sensor at t/b will not fit with ur ECU...
unless u mod...
but wiring have to cut like sotong!!!
ady fix evo t/b.prob solved.thx evryone.
thread closed
