Can Iswara Aeroback be changed to FR or 4WD?
a lot of option actually, but all old car and engine need to be transplanted, if you like big sedan then choose a bigger platform like cefiro, bmw e34, merc w124... all big and steady...
thanks for the info. hmm, i actually like a body something like wira aeroback quite balance and not too big. big sedan is quite heavy i think. hmm, can you show me where i can get a list of good and low price FR or 4WD cars, and drift potential also? i really don't know much about car names, or various types of cars out there :slug: i also cannot find in the internet because i dont know what to type lol. all that i type, the results are not relevant :P
id go ke70, can get a nicely souped up one, drift ready with a 4age for about 10k onwards (approx. only la hehe)
the balance can use for tires, etc. etc. and to fix up anything that goes wrong in the dorifto learning process hehe
OK! i've decided to go for the KE70:party:
hmm, have you ever experience drifting ke70? is it tough or easy?
have no idea :biggrin:
i play FF @$$-dragging only LoL even so i suck hehehe
all i noe is, cars with quite short wheelbase like the ae86 is not easy to drift hehehe
i see. hmm i wanna ask, how much cc the ke70 usually has, and how high can we upgrade the engine and still pass JPJ? i'm sure the stock ke70 engine is too weak to drift the car right? that's just a guess by the way :P
normally drift otais will tell u that all u need is an lsd, and get the car lowered...
normally it comes with a 1300cc engine
but might as well u just find one ke70 which already has a 4age / 4agze plonked inside, less hassles, no need to worry about jpj, etc. etc.
errr...what's a LSD? so sorry cause i still pretty new in car mods :P
hmm, how much cc does the 4age or 4agze have? also, how high can we upgrade the cc of this ke70, and still pass JPJ?:burnout:
limited-slip-differential, it helps to lock up ur tires, essential for drifting
those 4ages are 1600 cc engines....
u dont have to go higher than that...supercharged 4agze wud be nice and torquey....want more power, then convert the 4agze to a turbo setup, then u will meet mr.lag-a-little
Mr lag-a-little??? how come you said that?
hmm, yes 1.6 is quite good, maybe we wont have to go higher than that. hmm, do you know how much RM to install an LSD or supercharger?
Hmmm.....a bit details...
But simple....
LSD seal in gearbox which allow ur left & right wheel to move together in certain ratio...
Which mean if RWD drift with 2 wheel moving will be more nice & easy!!!
i see.
Hmm, do you know the price to install an LSD? and where can we get this LSD?:driver:
drifiting with ke70 modded with 4age -16v engine is great drift car for beginner.....easy and tail happy if u have the right wheel and right suspension setup...
u can upgrade until 20v black or silver top or u can opt for BOT, so far jpj approve and puspakom also no hassle if u have all the paper ready.
supercharged i not sure. lsd is approx 1.6k to 2k everything include installation...
i see.
finally i am selling my ke70 with 4age 16v - drift ready with racing clutch and trd suspension, if interested pls pm me to nego....
wow, thanks for the detailed info :D
and thanks for the offer too. although to be honest, i still got some issues with my mom, because she dislikes me buying cars like this though. got to get some more freedom first (which also means more cash) :P
But simple....
very diff to find a lsd alone...
I'm not really sure bout that...
So far...as i seen...Not many ppl really install themself gua........(correct me if i'm wrong)
All from jpn half...
example: mit's g/b, 4A g/b, Vtec g/b...all bought from japan h/c...
unless that b/b spoiled...them replace the lsd on the new g/b!!!
if u planning on a ke70, try source for ae86 rear axle with LSD... u can alwiz upgrade the LSD to TRD or Kaaz if u have the cash later...
if u dont have da cash for even ae86 rear axle, jz weld ur existing open diff axle together... it will act as full lock lsd and u'll have lots of fun buang here n there... kekekeke...
Bump: http://www.zerotohundred.com/newforums/engine-and-performance/265015-ke70-rear-lsd-2-5-a.html
thanks for the info :D
Bro Jack said that "LSD seal in gearbox which allow ur left & right wheel to move together in certain ratio". and you said that the LSD can be upgraded. what improvement will we have if we upgrade the LSD?
by the way, what "tail-happy" means?:driver:
upgrade LSD usually means upgrading to a stronger LSD unit which can stand higher horsepower.... it also allows stronger locking compare to oem units...
LSD are also wear n tear item if u didnt take care of it... LSD needs regular gear oil change....
tail happy means ur rear end of the car alwiz slides out... means u tend to oversteer often...
i see. in a drift car, is it better to have a tail-happy car or a strong understeer one?:driver:
