Hi All Honda Bro...Pls Help When Go Up Hill Car Will Vibrates:(
Eg Rocks
Hi All Bro...Pls help,when i go up hill my car will vibrates at certain speed 50-60.
than i go to one of the workshop ask them to check what is the problem...after they test drive & jack my car and check....they told me is drive shaft spoilt,but i said when conner dont have any sound (tak-tak-tak)then the mechanic said to me my both side drive shaft the inlet spoilt got loose...ok than i trust them walan:banghead: boths drive shaft they charge me $750 with installation lah... potong kerata punya pun mahal gila gua mesti kena potong kepala lah:slug: than nvm i trust them coz they repair alot of honda cars mostly vtec after change still same then the boss keep saying my old drive shaft got problem and my engine mounting not good WTF:damnmate:said my drive shaft got problem but change liao still same ask me change mounting i said other day.....he said my alignment is affected changing the drive shaft ask me go for alignment.....i go for alignment balancing every things i do still have the stupid vibrates....than i go back ask back my old drive shaft the boss start give me alot of excuse said u bring back no point dirty ur boot afterward all licking already i help u throwaway walan!!! tak boleh tahan man!!!!the boss nv slove my problem still bullshit all the way....now i read the boss mind my drive shaft sure noproblem thats why he want it.....i still take it back.....so now my car still vibrates leh any bro here got encounter this kinda problem????pls can help by the way im driving a Eg B16a Auto....is that Rm750 for boths drive shaft is worth it???i compare mine and the workshop sell me one mine abit loose lah hehehehe:rofl: but chnage liao still vibrates lah alamak:smokin::banghead:
where do u feel the vibration? engine? dashboard? tyres? steering?..... it could be a number of things...
i feel the vibration is come from the engine when during low speed 50-60 above the speed it will back to normal,my steering does vibrate and shake if steering & tyre....when i speed up to 140-160 it very stable just like normal....that workshop told me is mounting ,kinda strange if mounting problem,when i stop the car shift my gear to D it only vibrate abit just like other auto cars.....
Please post the shop name and location ..........
your middle drive shaft sudah rosak,if drive shaft left&right rosak ada bunyi(tak-tak-tak).your car dashborad also gegarkan.if u drive around 100km above not feel that problem correct.huhuhuhu expensive taht benkel nak ketuk u.u just find middle drive shaft at kedai potong bring to your fren workshop :biggrin::biggrin::biggrin: and change it.
the bengkel change for me whole set for both side also from kedai potong... still does make cents....kedai potong didnt sell u middle only they sell complete,i know i kena ketuk already:bawling: bro....any ideal :hmmmm:
did u check ur tyre also.....could b problem too..tayar kembung
i send my car to alignment & balancing they never mention my tyre problem...my tyre and rim just bought not even 1 year takan kembang kan:confused:
My guess its the middle engine mounting, hard to see without jacking the car up......try checking it,while ure at it check behind the engine block, there's an exhaust mounting connected that might of broken off (due to bumps n all) it can cause noises or vibration from the exhaust pipe hitting the engine block........no harm in checking....
Thanks bro:biggrin:.....i will chack it out the middle mounting.....i heard my friends said when change mouting ask foreman put silicon gum in the rubber part of the mounting it will tahan lame rite???:confused:
yes....it can last longer if you silicon in it, but its gonna be less comfortable, you'll feel the engine vibrate a little more & youll feel a bit more jerking on gear changes.....but i dont think youll notice it that much......
one more thing, buy the mounting(original RM150+-,imitation RM80+-,potong RM30+-) in advance and inject the silicon at least one day before for it to dry.....use windshield silicon R25(if im not mistaken....forgot th name la...its around RM30).....dont buy the one for roofing/tiles......ask the cermin shop....theyll know......gd. luck
