wira 4g13
asro
Hi.
I have a problem with my wira 4g13, when driving at 90++ km, the car feel like bumping and the power a bit drop but no semput. Recently I've already change 3 of the engine mounting and a set of tyre about 10 month ago... anybody can solve my pro:hmmmm:blem
Thanks Bro,
There is nothing problem on the fuel pump, I already go to workshop... and they said drive sharp, and change at the right hand side, and it ok for a while and then the problem come back again but not so bumping. buy and change at chop shop (4g91)... what should i do now because the problem still the same. :confused:
but he said he changed his tyre at about 10 months ago. Maybe flywheel bengkok already? Try to go skim it?
eeeek sry. i wanted to say flywheel not balance. no such word as bengkok. very sry for the typo
if there are vibrations when u accelerate around 90-100kmh.. the driveshaft kong already.. if u just changed one side. try changing the other side too...
another problem might be the ignition system.. it might be the spark plugs not good in condition... or it might be the plug cable...
recently, i skimmed my supertouring flywheel, but without balancing..some mech said no need..end result, my car vibrate at speed 110 - 130km/h..i think the flywheel need balancing..i think that can be your problem too..unbalanced flywheel..
Hi.
im agree with guan... coz i have problem like that first...
first of all check ur other driveshaft
(asking) did u ever heard a sound like "cluck" when u turn left or right in full steer??
after done driveshaft, is it still the same check ur engine balancing.. coz something the engine are not totally str8.. that make a problem too..
p/s : that is what i know n base on my experience.. :biggrin:
