ehem ehem, hehehehhe someone from this thread already jump to full turbo hafcut :P im not gonna tell whoooo, bt to tht guy, all the best bro, u will now feel the reliability of stock 280hp powered engine :P
any sifu know?the RHF5 turbine is same wif TD04?or smaller or bigger than it?tq
Bump: any sifu know?the RHF5 turbine is same wif TD04?or smaller or bigger than it?tq
sure the rhf5 bigger than the td04 ,last time i try the 4g91 engine bolt on turbo,that is damn fast,i share some exp here, use toyota 4agze piston bore is over size 83mm low com , rod can use mazda b6,1.8mm metal gasket,add the king bearing,arp nut,custom make banana and td05 20g,510 evo injector,tail 38mm waste gate,gsr head set and gti cam,mirco tech lt10s, evo fly wheel + exedy super single, evo 2 gear box + drive shaff,sard fuel ragulator,wabro 255liter perhour,boost 2bar can get 400whp,can rev to 10k rpm,all cost is over rm 40k but that is really fast
Bump:
sure the rhf5 bigger than the td04 ,last time i try the 4g91 engine bolt on turbo,that is damn fast,i share some exp here, use toyota 4agze piston bore is over size 83mm low com , rod can use mazda b6,1.8mm metal gasket,add the king bearing,arp nut,custom make banana and td05 20g,510 evo injector,tail 38mm waste gate,gsr head set and gti cam,mirco tech lt10s, evo fly wheel + exedy super single, evo 2 gear box + drive shaff,sard fuel ragulator,wabro 255liter perhour,boost 2bar can get 400whp,can rev to 10k rpm,all cost is over rm 40k but that is really fast![]()
Bro, u sure toyota supercahrger piston got 83mm ka...? I'll suggest 4age conrods if to be used on a 77.5 stroke. at least u don need to think about the conrod modding at the piston part.
AGREE ..... as what i know ..supercharged piston ...i dun think got 83mm
4G91 block Original piston size = 78.4mm
Upgraded to 83MM??!??!?!?? i think the block already BOCOR~ so I dun think the setup is right ...
4age conrods mod to 4G91 ??? i nv heard before...
Somemore Evo Flywheel mod into that gear box ??? its can install and doesnt fit nicely and there will be a trouble when drive....
and 510cc injector can support 400WHP?!?!?!? bro u sure or not .....
800cc Injector in my evo ...only can support 4xxwhp .....
then SARD / RC no need come out with aftermarket injector.. d
Base on logical side....... Normal Engine Block ........ the safest is Never bore more than 2mm ~~
hye~ i just want to ask from u guys~ does BOT will run smoothly with GEN 2 1.3 auto ?
Bump: hye~ i just want to ask from u guys~ does BOT will run smoothly with GEN 2 1.3 auto ?![]()
Well. 4age conrods on 4G91/92. Mod the crank.
Regardin the 2mm thing. Well, teh 4G91block and the 4G92 block basically came from the same mole. The only difference is the bore. That's what we call after cast machining. In other words, whatever maximum bore size that a 92 can cope, it can be coped by a 91.
Nothing wrong with EVO 3 flywheel into EVO 2 gb. But what's the point..?
And, 20g..??? Sure boh..? mae lag like hell..? Even GSR facing the same problem when plunge in a 16g EVO 3 which is suppose to be lighter.
And 4G91 400WHP...? Hehehehe.... Think twice before u say man...
And regarding the Campro BOT. And 2WD AUTO GB for NA car will never last more than 1/2 years when the car is turbocharged.
Regarding the BOT details, U need to find the engine specs, example bore size, stroke, CR etc. post it, then the otai otai will give suggestion.
Just to let you know there is already some 4G91 BOT using 81mm supercharger pistons without any heating problem. Boosting at 0.9bar...
And I am already using MIVEC block now. plunge in Supercharger pistons. Result same as the 4G91. also 0.6mm protuded from the block... But 4G93 is higher. That one I know...
4100rpm under low compression... I can;t imagine how it feels...
But anyway...chrissyong pls...
wahh..someone using my setting d wor ...
speed2horizon ..when go out yam char long time nv see u d lar~~~~~~~~
Yamen, long time no see. has been quite busy these days... U know lar, year end jor... Alot of stuff need to conclude...
WEll, about my car, Cause new pistons + new blocks + new rings + new bearings... Need to run in, hehe.... scared lar...
