1.6ers Owners (Mitsi/Proton)
just try it bro... then u will know.. hehe
but better if can removed or change the rev cut to 8000rpm.. standard only 6700rpm i think..
Bump: just try it bro... then u will know.. hehe
amd108, how fast also my car sure lose to you one.... coz ur car got secre recipe one... better than emanage
Wanna ask you guys, NA mods how high have u guys push this 1.6 litre powerplant while maintaining 1.6L SOHC?
Here is mine: Engine 4G92p
I maintain SOHC configuration, don't wanna mod to DOHC
Currently mine outputs 115HP at the wheels with the following mods:
1)PNPed cylinder head
2)Fast road spec cams
3)Quadcore 10mm plug cables + Denso Iridiums
4)LCP
5)4-2-1 Hot Bits header + 2" mendrel bend piping + bullet + Sflow muffler
6)Auto convert to manual with 1.8GB
7)K&N drop in air filter
8) Ported intake manifold to match + Perdana Sei TB
Bottom block still stock as well as the ECU and wiring. 15 years old engine, top overaul is done along with PNP process. Previously auto with the same mods was 100.3HP at the wheels
hye guys. i drove a 96' Satria 1.6.
currently, my car's throttle body is giving a problem. Before this the rpm is very very low and always dead when idle especially during morning and when aircond is on. Then go to workshop and they changed the gear/teeth but they said its only temporary because the "tapak" is melt already. I dont know what exactly he means because I wasnt there.
So, I've asked around looking for TB. The new one/original will set me back around RM800. The recond unit one is almost RM400 and the used one/halfcut is around RM250-RM300. Well actually I've changed my TB before but it was 4 years ago.. with recond unit. So its only last around 4 years before it start giving a problem. So guys, can you advice me on this? Should i go for used one or the recond one. Cant afford the new one...
Another thing is, a friend of mine who runs a workshop is offering me a GTI's TB and he is asking RM250 including installation. Is it a good deal? Does 1.8 TB make a difference in terms of fuel consumption and power?
Thanks!!!!
Bump: hye guys. i drove a 96' Satria 1.6.
Thanks!!!!
zeds: i'm selling my stock 92p tb for 100 bux only.. but got no tps.. u gotta use back urs...
any guys here selling 92p sohc high cams??? looking for 292 degrees or higher...
Bump: zeds: i'm selling my stock 92p tb for 100 bux only.. but got no tps.. u gotta use back urs...
is the tb still available??
Thanks!!!!
Thanks!!!!
Bro, u can try to fix the perdana none v6 tb, i use it last time without problem.....jz plug n play, no need mod....the respond oso fuyoo.....:burnout:
I also using Perdana Sei TB, good man ;)
Bump: I also using Perdana Sei TB, good man ;)
wow..i see lots of my fren are here too. haha~ how are u guys?
anyway, i'm driving satria 4g92p. change to manual 2 n half years ago. a short ratio perdana 1.6 gb to be exact. cost rm2k, fc is much more greater than previous(auto), n result i can drag with gti up to 200km/h. after that i quit. haha~ cheers~
Hie to all sifus of 4g92 'ers,
just bought satria 1.6 A last yr from my uncle. evthin is stock std. just a few ques here:
i) how 2 fix bubble on roof? best method + price
ii) 15" or 16" is better? currently using kyb gas frt n rr + stock springs
iii) tb tapak melted. which tb do u suggest to change? ori or perdana sei? pricing n suggestions?
iv) starter also showing signs 2 kong. any suggestions of starters?
v) lag n slight jerk when changing gears in high revs. is it normal 4 an auto?
vi) what is pcd stands 4? satria 1.6 A using 100 pcd kn?
vii) does anybody recommend icharge?
tq
p/s : i know its a long list. will add some soon after all of these probs is solved. hehe :Rofl:
Bump: Hie to all sifus of 4g92 'ers,
tq
tq
tq
i) There's no best method. There's only one method. Change the whole roof. Yup, it is expensive but thats the only way. Well, actually there's another way but it is tedious and the bubble can appear back in a year or less.
ii) 15". Tire is much cheaper than 16" for sure.
iii) Perdana Sei is much recommended. Can get more power. Should not cost you more than 400 for a recond unit but I recommend you to look out at chopshop first.
iv, v) Dont have any experience in this. My 12 years old Satria can start without any problem.
vi) Satria, Wira = PCD100 Iswara, Waja = PCD114.3
vii) icharge? Dont know what the heck is that. Sorry.
Hope this helps.
Hope this helps.
tq sifu zedz. d info does help me. tq again
i-charge is the thing that plug into cigarrets hole at dashboard.. it function is to stabilize the volt..
but in my opinion that thing cost too much, rm650 if not mistaken.. oredy can buy 2nd e-manage bro..
Guys any of u selling their wira 1st or 2nd model 14" sports rim or 14' wheel cover
original 1.6.
Just bought a wira & it's funny without the orig rim.
012218 4747 TQ
Bump: Guys any of u selling their wira 1st or 2nd model 14" sports rim or 14' wheel cover
original 1.6.
012218 4747 TQ
