Proton 4g13 Power Steering Weird Sound During Turning
4G15P_Asthma
My 3 year old Wira SE also got sound very soft "tak tak tak" sound when turning from a standstill especially if the ground not perfectly flat
Mechanic said not the drive-shaft, tested doing U-turn million of times until almost puke but no sound came out
He said maybe the stabilizer suspension related :hmmmm:
realplayer
330
Hey friend,
How much you got the "vacum controller" installed?
Yup, I read from forum some of the ZTH member did installed it. Some will good feedback some are not! So I am thinking to get one as well.
The said go for "FICD" Fast Idle Control Device.... But are your's is the FICD??????
For this few days, the weird sound gone... I might need to see further it might come back neh.
I replaced the ori plug cable with "Pro Ralley High Performance Plug Cable" added with Bosch Super4 spark plug..... Can feel that the car gainning some power compared to previous with ori spark plug & plug cable.
Might wanna to try out the Pivot Voltage Stabilizer with grounding as well.
Any advise or suggestion?:driver:
How much??....i just pay RM40.00 for the thing and installation...member punya workshop...:proud:..i have see the FICD, and i'm sure mine not same with that FICD..that why (maybe) the mechanic call it "vacum controller"...
viostar
475
2
My colleague got one unit in his car & he plan to take it out than install to my car to test on it. See any difference or any improvement !
If ok than I plan to purchase 1 unit too.
Wait for my update on the test result ya!
Bump:
Might be some nut lose & not tide properly. during turn than sound appear!
Better check where the sound come from!
This few days my car is OK no sound during turning on the steering. Why???... I also do know...
Ai... old car, I think.
realplayer
330
hai viostar...back to the topic....izit sound come from bosskit??...have you try to change it?...:biggrin:
4G15P_Asthma
U know what, da funny (or scary) thing was whenever I bring my car to the workshop the tak-tak-tak sound disappear!
Maybe my car "MERAJUK" when I said "Wow that new Satria Neo looks cool man! I must get CPS GTi R3 version someday!"
Nowadays even car got feelings...
ExceL
1,726
162
Ampang/KL
is yours a S-VDO model?..if yes, your probably right
:biggrin:
4G15P_Asthma
Yeah the crap ECU, I was desperate back then to get rid off my Kancil R85 GTR
MyVi had to wait 6 months, so I opt for Wira so called Special Edition :confused:
Within budget la bro
No other theory yet for the tak-tak-tak sound, very frustrating man! 2 years warranty expired already, damn!
Farmi Izudin
32
Maybe your steering spoke got a problem.. the sound screeching comes from the horn steel connection for horn system,,, put some oil lubricant at the aluminum would be just fine.. I think..
hope this helps..:idea:
viostar
475
2
bosskit??
I am still using the ori steering from proton wow! never change sport steering neh!
please correct me if i am wrong.
Bump:
emm... i will try that out.
TQ.
Kevinfan
4
Viostar, for your problem. Here is my experience... It's most probably is the power steering pump got problem. What i do is service the pump with changing the power steering kit, it include some o-ring. oil seal etc.... Main problem is all the rubber kit harden. only the kit itself cost less <rm100.. good luck.
viostar
475
2
Hi Kevinfan,...
I may ask the workshop to service it.... Thanks bro..
4G15P_Asthma
Hehe just got back my 73k service.
My mechanic the "tak-tak-tak" sound comes from a knuckle twisting (when we steer) located under the adjustable steering, but the damn whole cover set must be taken off to see it clearly.
Time consuming, I've become fedup :sleep: & went home, so to be continued...
jimmygolerro
Jan 15, 2014
9
503
I know that this is an old thread. But anyone has the solution to solve this problem? Mine having the same problem and it seems to go away and comes back as it wishes. I just hope it's nothing serious. How can I fix it??? Thank you guys
desmond0318
467
48
what sound u're mentioning? Check steering bush, boot, tie rod end and driveshaft, worse goes to steering rack :biggrin:
Hi there sifus! I wanted to ask for my car. I just got it like couple of days ago going on 350km already on the ODOMETER.
Somehow, havent' got my 1st service yet though. Wanted to ask for advises.
Here is my plan.
1.Changing tire rims from 14" to 15", probably normal ones. Looked around a lot people say stabilizes the car and better comfort. What do you guys think? Around RM1500 with tires together.
2.Changing light weighted crank pulleys, does this improve anything? I heard it...
