- Joined
- Sep 22, 2008
- Messages
- 1,246
- Points
- 1,638
At DragStar Peformance Centre Sdn. Bhd, we also carries pistons for all Japaness type of cars from Honda, Mitsubishi, Nissan, Toyota & Subaru at Malaysia. The piston that we carries in Malaysia is from CP Piston which is forged piston & one of the best piston that been make for the fast car in the Motorsports arena. So here is the lists of all the CP Piston that DragStar Performance Centre Sdn. Bhd bring in for all you guys out there & more various choices for you all to choose.
http://i107.photobucket.com/albums/m306/babymelon_lst/dragstar/sc7100.jpg
http://i107.photobucket.com/albums/m306/babymelon_lst/dragstar/cppistonsc7000.jpg
http://i107.photobucket.com/albums/m306/babymelon_lst/dragstar/cppistonsc7001.jpg
APPLICATION CODES"
1- TURBO / SUPERCHARGER
2- NITROUS
3- NATURALLY ASPIRATED
4- WORKS w/ B16A / B18A / B18B / B18C HEAD
5- MUST SLEEVE BLOCK
6- 5SFE BLOCK with 3SGTE HEAD
7- CR with KA24DE IS 9.0:1, KA24E IS 8.0:1
8- CR with 89mm STROKE & B16A HEAD
9- NO LOCKS SUPPLIED, USE FACTORY LOCKS
* X-STYLE FORGING
HONDA
PART NO# SC7000
ENGINE:B61A
BORE:3.189" 81.0mm
CR:9
APPLICATION:1,2,4
PART NO# SC7001
ENGINE:B61A
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2,4
PART NO# SC7100
ENGINE:B61A
BORE:3.189" 81.0mm
CR:10.5
APPLICATION:2,3,4
PART NO# SC7101
ENGINE:B61A
CORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:10.5
APPLICATION:2,3,4
PART NO# SC7005
ENGINE:B18A1 / B1
BORE:3.189" 81.0mm
CR:9
APPLICATION:1,2,4
PART NO# SC7006
ENGINE:B18A1 / B1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2,4
PART NO# SC7105
ENGINE:B18A1 / B1
BORE:3.189" 81.0mm
CR:10.5
APPLICATION:2,3,4
PART NO# SC7106
ENGINE:B18A1 / B1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:10.5
APPLICATION:2,3,4
PART NO# SC7010
ENGINE:B18C1
BORE:3.189" 81.0mm
CR:9
APPLICATION:1,2,4
PART NO# SC7011
ENGINE:B18C1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2,4
PART NO# SC7014
ENGINE:B18C1
BORE:3.228" 82.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2,4
PART NO# SC7012
ENGINE:B18C1
BORE:3.268" 83.0mm
SIZE:+.080 / +2.0mm
CR:9
APPLICATION:1,2,4
PART NO# SC7015
ENGINE:B18C1
BORE:3.189" 81.0mm
CR:9.8
APPLICATION:1,2,3,4
PART NO# SC7016
ENGINE:B18C1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:9.8
APPLICATION:1,2,3,4
PART NO# SC7013
ENGINE:B18C1
BORE:3.268" 83.0mm
SIZE:+.080 / +2.0mm
CR:9.8
APPLICATION:1,2,3,4
PART NO# SC7110
ENGINE:B18C1
BORE:3.189" 81.0mm
CR:11
APPLICATION:2,3,4
PART NO# SC7111
ENGINE:B18C1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:11
APPLICATION:2,3,4
PART NO# SC7113
ENGINE:B18C1
BORE:3.228" 82.0mm
SIZE:+.040 / +1.0mm
CR:11
APPLICATION:2,3,4
PART NO# SC7112
ENGINE:B18C1
BORE:3.268" 83.0mm
SIZE:+.080 / +2.0mm
CR:11
APPLICATION:2,3,4
PART NO# SC7115
ENGINE:B18C1
BORE:3.189" 81.0mm
CR:12.5
APPLICATION:3,4
PART NO# SC7116
ENGINE:B18C1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:12.5
APPLICATION:3,4
PART NO# SC7114
ENGINE:B18C1
BORE:3.228" 82.0mm
SIZE:+.040 / +1.0mm
CR:12.5
APPLICATION:3,4
PART NO# SC7115X*
ENGINE:B18C1
BORE:3.189" 81.0mm
CR:12.5
APPLICATION:3,4
PART NO# SC7116X*
ENGINE:B18C1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:12.5
APPLICATION:3,4
PART NO# SC7135
ENGINE:B18C5
BORE:3.189" 81.0mm
CR:11.5
APPLICATION:2,3,4
PART NO# SC7136
ENGINE:B18C5
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:11.5
APPLICATION:2,3,4
PART NO# SC7020
ENGINE:B-SERIES
BORE:3.307" 84.0mm
CR:9
APPLICATION:1,2,4,8
PART NO# SC7021
ENGINE:B-SERIES
BORE:3.327" 84.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2,4,8
PART NO# SC7022
ENGINE:B-SERIES
BORE:3.346" 85.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2,4,8
PART NO# SC7017
ENGINE:B-SERIES
BORE:3.307" 84.0mm
CR:9.7
APPLICATION:1,2,4,8
PART NO# SC7018
ENGINE:B-SERIES
BORE:3.327" 84.5mm
SIZE:+.020 / +0.5mm
CR:9.7
APPLICATION:1,2,4,8
PART NO# SC7019
ENGINE:B-SERIES
BORE:3.346" 85.0mm
SIZE:+.040 / +1.0mm
CR:9.7
APPLICATION:1,2,4,8
PART NO# SC7117
ENGINE:B-SERIES
BORE:3.307" 84.0mm
CR:11.5
APPLICATION:2,3,4,8
PART NO# SC7118
ENGINE:B-SERIES
BORE:3.327" 84.5mm
SIZE:+.020 / +0.5mm
CR:11.5
APPLICATION:2,3,4,8
PART NO# SC7119
ENGINE:B-SERIES
BORE:3.346" 85.0mm
SIZE:+.040 / +1.0mm
CR:11.5
APPLICATION:2,3,4,8
PART NO# SC7120
ENGINE:B-SERIES
BORE:3.307" 84.0mm
CR:12.5
APPLICATION:2,3,4,8
PART NO# SC7121
ENGINE:B-SERIES
BORE:3.327" 84.5mm
SIZE:+.020 / +0.5mm
CR:12.5
APPLICATION:2,3,4,8
PART NO# SC7122
ENGINE:B-SERIES
BORE:3.346" 85.0mm
SIZE:+.040 / +1.0mm
CR:12.5
APPLICATION:2,3,4,8
PART NO# SC7123X
ENGINE:B-SERIES
BORE:3.346" 85.0mm
SIZE: +.040 / +1.0mm
CR:7.7
APPLICATION:3,4
PART NO# SC7124X
ENGINE:B-SERIES
BORE:3.386" 86.0mm
SIZE:+.080 / +2.0mm
CR:7.7
APPLICATION:3,4
PART NO# SC7060
ENGINE:F20C
BORE:3.425" 87.0mm
CR:9
APPLICATION:1,2,5
PART NO# SC7061
ENGINE:F20C
BORE:3.445" 87.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2,5
PART NO# SC7062
ENGINE:F20C
BORE:3.465" 88.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2,5
PART NO# SC7040
ENGINE:K20A / A2 / A3
BORE:3.386" 86.0mm
CR:9
APPLICATION:1,2
PART NO# SC70401
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC70402
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2
PART NO# SC70403
BORE:3.465" 88.0mm
SIZE:+.080 / +2.0mm
CR:9
APPLICATION:1,2
PART NO# SC70404
BORE:3.504" 89.0mm
SIZE:+.120 / +3.0mm
CR:9
APPLICATION:1,2
PART NO# SC7140
BORE:3.386" 86.0mm
CR:11.5
APPLICATION:2,3
PART NO# SC71401
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:11.5
APPLICATION:2,3
PART NO# SC71402
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:11.5
APPLICATION:2,3
PART NO# SC71403
BORE:3.465" 88.0mm
SIZE:+.080 / +2.0mm
CR:11.5
APPLICATION:2,3
PART NO# SC71404
BORE:3.504" 89.0mm
SIZE:+.120 / +3.0mm
CR:11.5
APPLICATION:2,3
PART NO# SC71405
BORE:3.543" 90.0mm
SIZE:+.160 / +4.0mm
CR:11.5
APPLICATION:2,3
PART NO# SC7142X*
BORE:3.386" 86.0mm
CR:12.5
APPLICATION:3
PART NO# SC71421X*
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:12.5
APPLICATION:3
PART NO# SC71422X*
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:12.5
APPLICATION:3
PART NO# SC71423X*
BORE:3.465" 88.0mm
SIZE:+.080 / +2.0mm
CR:12.5
APPLICATION:3
PART NO# SC71424X*
BORE:3.504" 89.0mm
SIZE:+.120 / +3.0mm
CR:12.5
APPLICATION:3
PART NO# SC71425X*
BORE:3.543" 90.0mm
SIZE:+.160 / +4.0mm
CR:12.5
APPLICATION:3
PART NO# SC7030
ENGINE:H22
BORE:3.425" 87.0mm
CR:9
APPLICATION:1,2,5
PART NO# SC7031
ENGINE:H22
BORE:3.445" 87.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2,5
PART NO# SC7034
ENGINE:H22
BORE:3.465" 88.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2,5
PART NO# SC7130
ENGINE:H22
BORE:3.425" 87.0mm
CR:10
APPLICATION:2,3,5
PART NO# SC7131
ENGINE:H22
BORE:3.425" 87.0mm
CR:11.5
APPLICATION:2,3,5
MITSUBISHI
PART NO# SC7200
ENGINE:4G63 1G
BORE:3.366" 85.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC7202
ENGINE:4G63 1G
BORE:3.386" 86.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2
PART NO# SC7201
ENGINE:4G63 2G / EVO VIII
BORE:3.366" 85.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC7203
BORE:3.386" 86.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2
PART NO# SC7205
ENGINE:Stroker 4G63 1G
BORE:3.366" 85.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC7207
BORE:3.386" 86.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2
PART NO# SC7206
ENGINE:Stroker 4G63 2G / EVO VIII
BORE:3.366" 85.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC7208
BORE:3.386" 86.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2
SUBARU
PART NO# SC7400
ENGINE:EJ20 WRX
BORE:3.642" 92.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2,9
PART NO# SC7410
ENGINE:EJ25
BORE:3.937" 100.0mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2,9
PART NO# SC7420
ENGINE:EJ257 WRX STI
BORE:3.9175" 99.5mm
CR:8.2
APPLICATION:1,2,9
PART NO# SC7421
BORE:3.937" 100.0mm
SIZE:+.020 / +0.5mm
CR:8.2
APPLICATION:1,2,9
TOYOTA
PART NO# SC7459
ENGINE:2JZGTE
BORE:3.386" 86.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7460
ENGINE:2JZGTE
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2
PART NO# SC7461
ENGINE:2JZGTE
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7449
ENGINE:3SGTE
BORE:3.386" 86.0mm
CR:9
APPLICATION:1,2
PART NO# SC7450
ENGINE:3SGTE
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC7451
ENGINE:5SFE / 3SGTE
BORE:3.445" 87.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2,6
NISSAN
PART NO# SC7307
ENGINE:RB25DET
BORE:3.386" 86.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7308
ENGINE:RB25DET
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2
PART NO# SC7309
ENGINE:RB26DETT
BORE:3.386" 86.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7310
ENGINE:RB26DETT
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2
PART NO# SC7311
ENGINE:RB26DETT
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7320
ENGINE:SR20DE / SR20DET
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:10.5
APPLICATION:1,2,3
PART NO# SC7321
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:10.5
APPLICATION:1,2,3
PART NO# SC7324
ENGINE:SR20DE Turbo / SR20DET
BORE:3.386" 86.0mm
CR:9
APPLICATION:1,2
PART NO# SC7325
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC7326
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2
PART NO# SC7329
BORE:3.543" 90.0mm
SIZE:+0.157 / +4.0mm
CR:9
APPLICATION:1,2
PART NO# SC73241
BORE:3.386" 86.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7327
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2
PART NO# SC7328
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC73291
BORE:3.543" 90.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7330
ENGINE:VG30DE
BORE:3.445" 87.5mm
SIZE:+.020 / +0.5mm
CR:10.5
APPLICATION:2,3
PART NO# SC7335
ENGINE:VG30DETT
BORE:3.445" 87.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2
PART NO# SC7336
ENGINE:VG30DETT
BORE:3.465" 88.0mm
SIZE:+.040 / +1.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7337
ENGINE:VQ35DE
BORE:3.760" 95.5mm
CR:8.5
APPLICATION:1,2
PART NO# SC7338
ENGINE:VQ35DE
BORE:3.780" 96.0mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2
SC73371
ENGINE:VQ35DE
BORE:3.760" 95.5mm
CR:11
APPLICATION:2,3
SC73381
ENGINE:VQ35DE
BORE:3.780" 96.0mm
SIZE:+.020 / +0.5mm
CR:11
APPLICATION:2,3
Dealing method:
COD
Location of seller:
No. C-1, Jalan PJU 1/45,
Aman Suria Damansara,
47301, Petaling Jaya
Selangor Darul Ehsan.
Contact method/details:
Tel: 03-7880 4804
Fax: 03-7805 2604
Email: [email protected]
Website: www.dragstar.com.my
Operation hours:
Saturday - Wednesday
11am - 8pm
Age of item:
NEW
APPLICATION CODES"
2- NITROUS
* X-STYLE FORGING
HONDA
PART NO# SC7000
ENGINE:B61A
BORE:3.189" 81.0mm
CR:9
APPLICATION:1,2,4
PART NO# SC7001
ENGINE:B61A
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2,4
PART NO# SC7100
ENGINE:B61A
BORE:3.189" 81.0mm
CR:10.5
APPLICATION:2,3,4
PART NO# SC7101
ENGINE:B61A
CORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:10.5
APPLICATION:2,3,4
PART NO# SC7005
ENGINE:B18A1 / B1
BORE:3.189" 81.0mm
CR:9
APPLICATION:1,2,4
PART NO# SC7006
ENGINE:B18A1 / B1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2,4
PART NO# SC7105
ENGINE:B18A1 / B1
BORE:3.189" 81.0mm
CR:10.5
APPLICATION:2,3,4
PART NO# SC7106
ENGINE:B18A1 / B1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:10.5
APPLICATION:2,3,4
PART NO# SC7010
ENGINE:B18C1
BORE:3.189" 81.0mm
CR:9
APPLICATION:1,2,4
PART NO# SC7011
ENGINE:B18C1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2,4
PART NO# SC7014
ENGINE:B18C1
BORE:3.228" 82.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2,4
PART NO# SC7012
ENGINE:B18C1
BORE:3.268" 83.0mm
SIZE:+.080 / +2.0mm
CR:9
APPLICATION:1,2,4
PART NO# SC7015
ENGINE:B18C1
BORE:3.189" 81.0mm
CR:9.8
APPLICATION:1,2,3,4
PART NO# SC7016
ENGINE:B18C1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:9.8
APPLICATION:1,2,3,4
PART NO# SC7013
ENGINE:B18C1
BORE:3.268" 83.0mm
SIZE:+.080 / +2.0mm
CR:9.8
APPLICATION:1,2,3,4
PART NO# SC7110
ENGINE:B18C1
BORE:3.189" 81.0mm
CR:11
APPLICATION:2,3,4
PART NO# SC7111
ENGINE:B18C1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:11
APPLICATION:2,3,4
PART NO# SC7113
ENGINE:B18C1
BORE:3.228" 82.0mm
SIZE:+.040 / +1.0mm
CR:11
APPLICATION:2,3,4
PART NO# SC7112
ENGINE:B18C1
BORE:3.268" 83.0mm
SIZE:+.080 / +2.0mm
CR:11
APPLICATION:2,3,4
PART NO# SC7115
ENGINE:B18C1
BORE:3.189" 81.0mm
CR:12.5
APPLICATION:3,4
PART NO# SC7116
ENGINE:B18C1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:12.5
APPLICATION:3,4
PART NO# SC7114
ENGINE:B18C1
BORE:3.228" 82.0mm
SIZE:+.040 / +1.0mm
CR:12.5
APPLICATION:3,4
PART NO# SC7115X*
ENGINE:B18C1
BORE:3.189" 81.0mm
CR:12.5
APPLICATION:3,4
PART NO# SC7116X*
ENGINE:B18C1
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:12.5
APPLICATION:3,4
PART NO# SC7135
ENGINE:B18C5
BORE:3.189" 81.0mm
CR:11.5
APPLICATION:2,3,4
PART NO# SC7136
ENGINE:B18C5
BORE:3.209" 81.5mm
SIZE:+.020 / +0.5mm
CR:11.5
APPLICATION:2,3,4
PART NO# SC7020
ENGINE:B-SERIES
BORE:3.307" 84.0mm
CR:9
APPLICATION:1,2,4,8
PART NO# SC7021
ENGINE:B-SERIES
BORE:3.327" 84.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2,4,8
PART NO# SC7022
ENGINE:B-SERIES
BORE:3.346" 85.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2,4,8
PART NO# SC7017
ENGINE:B-SERIES
BORE:3.307" 84.0mm
CR:9.7
APPLICATION:1,2,4,8
PART NO# SC7018
ENGINE:B-SERIES
BORE:3.327" 84.5mm
SIZE:+.020 / +0.5mm
CR:9.7
APPLICATION:1,2,4,8
PART NO# SC7019
ENGINE:B-SERIES
BORE:3.346" 85.0mm
SIZE:+.040 / +1.0mm
CR:9.7
APPLICATION:1,2,4,8
PART NO# SC7117
ENGINE:B-SERIES
BORE:3.307" 84.0mm
CR:11.5
APPLICATION:2,3,4,8
PART NO# SC7118
ENGINE:B-SERIES
BORE:3.327" 84.5mm
SIZE:+.020 / +0.5mm
CR:11.5
APPLICATION:2,3,4,8
PART NO# SC7119
ENGINE:B-SERIES
BORE:3.346" 85.0mm
SIZE:+.040 / +1.0mm
CR:11.5
APPLICATION:2,3,4,8
PART NO# SC7120
ENGINE:B-SERIES
BORE:3.307" 84.0mm
CR:12.5
APPLICATION:2,3,4,8
PART NO# SC7121
ENGINE:B-SERIES
BORE:3.327" 84.5mm
SIZE:+.020 / +0.5mm
CR:12.5
APPLICATION:2,3,4,8
PART NO# SC7122
ENGINE:B-SERIES
BORE:3.346" 85.0mm
SIZE:+.040 / +1.0mm
CR:12.5
APPLICATION:2,3,4,8
PART NO# SC7123X
ENGINE:B-SERIES
BORE:3.346" 85.0mm
CR:7.7
APPLICATION:3,4
PART NO# SC7124X
ENGINE:B-SERIES
BORE:3.386" 86.0mm
SIZE:+.080 / +2.0mm
CR:7.7
APPLICATION:3,4
PART NO# SC7060
ENGINE:F20C
BORE:3.425" 87.0mm
CR:9
APPLICATION:1,2,5
PART NO# SC7061
ENGINE:F20C
BORE:3.445" 87.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2,5
PART NO# SC7062
ENGINE:F20C
BORE:3.465" 88.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2,5
PART NO# SC7040
BORE:3.386" 86.0mm
CR:9
APPLICATION:1,2
PART NO# SC70401
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC70402
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2
PART NO# SC70403
BORE:3.465" 88.0mm
SIZE:+.080 / +2.0mm
CR:9
APPLICATION:1,2
PART NO# SC70404
BORE:3.504" 89.0mm
SIZE:+.120 / +3.0mm
CR:9
APPLICATION:1,2
PART NO# SC7140
BORE:3.386" 86.0mm
CR:11.5
APPLICATION:2,3
PART NO# SC71401
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:11.5
APPLICATION:2,3
PART NO# SC71402
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:11.5
APPLICATION:2,3
PART NO# SC71403
BORE:3.465" 88.0mm
SIZE:+.080 / +2.0mm
CR:11.5
APPLICATION:2,3
PART NO# SC71404
BORE:3.504" 89.0mm
SIZE:+.120 / +3.0mm
CR:11.5
APPLICATION:2,3
PART NO# SC71405
BORE:3.543" 90.0mm
SIZE:+.160 / +4.0mm
CR:11.5
APPLICATION:2,3
PART NO# SC7142X*
BORE:3.386" 86.0mm
CR:12.5
APPLICATION:3
PART NO# SC71421X*
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:12.5
APPLICATION:3
PART NO# SC71422X*
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:12.5
APPLICATION:3
PART NO# SC71423X*
BORE:3.465" 88.0mm
SIZE:+.080 / +2.0mm
CR:12.5
APPLICATION:3
PART NO# SC71424X*
BORE:3.504" 89.0mm
SIZE:+.120 / +3.0mm
CR:12.5
APPLICATION:3
PART NO# SC71425X*
BORE:3.543" 90.0mm
SIZE:+.160 / +4.0mm
CR:12.5
APPLICATION:3
PART NO# SC7030
ENGINE:H22
BORE:3.425" 87.0mm
CR:9
APPLICATION:1,2,5
PART NO# SC7031
ENGINE:H22
BORE:3.445" 87.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2,5
PART NO# SC7034
ENGINE:H22
BORE:3.465" 88.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2,5
PART NO# SC7130
ENGINE:H22
BORE:3.425" 87.0mm
CR:10
APPLICATION:2,3,5
PART NO# SC7131
ENGINE:H22
BORE:3.425" 87.0mm
CR:11.5
APPLICATION:2,3,5
MITSUBISHI
PART NO# SC7200
ENGINE:4G63 1G
BORE:3.366" 85.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC7202
ENGINE:4G63 1G
BORE:3.386" 86.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2
PART NO# SC7201
BORE:3.366" 85.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC7203
BORE:3.386" 86.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2
PART NO# SC7205
BORE:3.366" 85.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC7207
BORE:3.386" 86.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2
PART NO# SC7206
BORE:3.366" 85.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC7208
BORE:3.386" 86.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2
SUBARU
PART NO# SC7400
ENGINE:EJ20 WRX
BORE:3.642" 92.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2,9
PART NO# SC7410
ENGINE:EJ25
BORE:3.937" 100.0mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2,9
PART NO# SC7420
BORE:3.9175" 99.5mm
CR:8.2
APPLICATION:1,2,9
PART NO# SC7421
BORE:3.937" 100.0mm
SIZE:+.020 / +0.5mm
CR:8.2
APPLICATION:1,2,9
TOYOTA
PART NO# SC7459
ENGINE:2JZGTE
BORE:3.386" 86.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7460
ENGINE:2JZGTE
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2
PART NO# SC7461
ENGINE:2JZGTE
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7449
ENGINE:3SGTE
BORE:3.386" 86.0mm
CR:9
APPLICATION:1,2
PART NO# SC7450
ENGINE:3SGTE
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC7451
ENGINE:5SFE / 3SGTE
BORE:3.445" 87.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2,6
NISSAN
PART NO# SC7307
ENGINE:RB25DET
BORE:3.386" 86.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7308
ENGINE:RB25DET
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2
PART NO# SC7309
ENGINE:RB26DETT
BORE:3.386" 86.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7310
ENGINE:RB26DETT
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2
PART NO# SC7311
ENGINE:RB26DETT
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7320
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:10.5
APPLICATION:1,2,3
PART NO# SC7321
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:10.5
APPLICATION:1,2,3
PART NO# SC7324
BORE:3.386" 86.0mm
CR:9
APPLICATION:1,2
PART NO# SC7325
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:9
APPLICATION:1,2
PART NO# SC7326
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:9
APPLICATION:1,2
PART NO# SC7329
BORE:3.543" 90.0mm
CR:9
APPLICATION:1,2
PART NO# SC73241
BORE:3.386" 86.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7327
BORE:3.406" 86.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2
PART NO# SC7328
BORE:3.425" 87.0mm
SIZE:+.040 / +1.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC73291
BORE:3.543" 90.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7330
ENGINE:VG30DE
BORE:3.445" 87.5mm
SIZE:+.020 / +0.5mm
CR:10.5
APPLICATION:2,3
PART NO# SC7335
ENGINE:VG30DETT
BORE:3.445" 87.5mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2
PART NO# SC7336
ENGINE:VG30DETT
BORE:3.465" 88.0mm
SIZE:+.040 / +1.0mm
CR:8.5
APPLICATION:1,2
PART NO# SC7337
ENGINE:VQ35DE
BORE:3.760" 95.5mm
CR:8.5
APPLICATION:1,2
PART NO# SC7338
ENGINE:VQ35DE
BORE:3.780" 96.0mm
SIZE:+.020 / +0.5mm
CR:8.5
APPLICATION:1,2
SC73371
ENGINE:VQ35DE
BORE:3.760" 95.5mm
CR:11
APPLICATION:2,3
SC73381
ENGINE:VQ35DE
BORE:3.780" 96.0mm
SIZE:+.020 / +0.5mm
CR:11
APPLICATION:2,3
Dealing method:
COD
Location of seller:
Tel: 03-7880 4804
Fax: 03-7805 2604
Operation hours:
11am - 8pm
Age of item:
NEW
