Bro, I 've got no idea on CAMPRO engine. But to confirm it, U need to check on the Bore(diameter) and the Stroke of ur engine. Because those are the things that determine the fitting.. And most importantly, the method of holding the piston onto the conrod and the diameter of the piston rod. For example, Mitsu uses force fitting piston rod, toyota and nissan uses clips.
can. But u need to bore up the block to 81mm. Then U'll have 1.6 instead. Some ppl said max boring is 2mm in diameter... Not for this case... because the block configuration is exactly the same as 4G92. I have a friend already done it and turbo charged the engine.
One side says that turbos help make use of wasted heat energy and exhaust gases as well as increasing volumetric efficiency, thus making then engine more efficient and...
You’ve no doubt been reading a lot of news about Lamborghini Kuala Lumpur across the digital pages on Zerotohundred recently. This is clear indication of their steadily growing presence here in Malaysia. Yesterday...
