Bro, I 've got no idea on CAMPRO engine. But to confirm it, U need to check on the Bore(diameter) and the Stroke of ur engine. Because those are the things that determine the fitting.. And most importantly, the method of holding the piston onto the conrod and the diameter of the piston rod. For example, Mitsu uses force fitting piston rod, toyota and nissan uses clips.
can. But u need to bore up the block to 81mm. Then U'll have 1.6 instead. Some ppl said max boring is 2mm in diameter... Not for this case... because the block configuration is exactly the same as 4G92. I have a friend already done it and turbo charged the engine.
It has been a while since we last went to Goh Tong Jaya through the winding roads of Ulu Yam. After a long hiatus, the boys and ourselves got together for a breakfast by which was an atypical...
Can any tai ko told me how to connect the light with woofer base???
when the base come,the light will shining
If u know pls draw the eletrik picture too ok
THANK :D
