- Joined
- Jan 11, 2007
- Messages
- 1,342
- Points
- 5,148
initial pickup? not quite sure what u mean
u mean when the clutch bites? and gets going? smaller always means easier to turn/spin, but the advantage here is that even though the clutch looks small, but it still bites
the larger oem clutch, what i worry is that it will not bite once u go crazy on the pedal
ori clutches are always meant to slip a little bit as it is made for the general user, who will find it more comfortable and easier to use
so far la, been pushing the clutch hard, so far so good
mebbe u shud try larger clutches on ur ori flywheel first, and if it is enough, then no need look at other options edi
if not enough, then just find another ori 1.3/1.5 flywheel which has not yet been 'tebuk-ed' and throw in the plug n play 3 puck clutch, if u worry about durability la, if not then use back ori 'tebuk-ed' one i guess but there's always the uncertainty hehe
But this will heavily depend also on how u use it, im hoping to stretch it to 2 years if can la hehe
