BRAND NEW XYZ BIG BRAKE KIT FOR SALE!!!!!
XYZ was founded in 1998, Taiwan-based leading manufacturer and supplier of high performance coilover and brake systems with 150,000 sq. ft. manufacturing facility. . XYZ has had excellent experience of making high performance for over 10 years, all product designers with over 10 years background in international racing competitions are retried and work as engineering and testing team.
We have been committed to making and offering quality products for a few well-known brands in Japan and USA, and combine European, American and Japanese technical expertise, capture advanced process knowledge, continue R&D through innovation for high end auto sport parts and solidifying our leadership position in motor sport industry. All XYZ components are inspected strictly through quality control program, and all products are manufactured in accordance with ISO 9001 standards. We have made custom coilover systems for over 70 racers worldwide so far.
We are a sponsor of Alfa Romeo Racing Team at WTCC (World Touring Car Championship) for 2006 and 2007 and of ACSCA in 2006 and 2007. Our products are test fit on physical vehicles through global racing teams, in addition, we use the advanced equipment to test each set. XYZ equipped vehicles have captured numerous racing championships.
Innovation, technology and quality are XYZ commitments to consumers. We will continue development through innovation of brake and suspension technology. We bring you to the ultimate performance, it’s much more than a slogan.
XYZ Auto Parts
Front Brake Kit:
1. 6 pots with 286mm rotor
A complete brake kit content:
2-piece 286mm x 26mm slotted rotor x 2pcs.
Lightweight aluminum centre hat x 2pcs.
6-piston caliper (painted red, yellow or anodized gold, black or any other painted colors.) x 2pcs.
Caliper mounting bracket x 2pcs.
Stainless steel brake line x 2pcs.
High performance sport brake pads x 4 pcs/ 1set (race pads are optional).
Tool kit x 1.
Features:
Rotor thickness 26mm.
Rotor with larger vents to have ability to dissipate heat.
Lightweight aluminum centre hat with hard anodizing electrolyte treatment for durability.
Squeeze forged 6-piston caliper (painted red, yellow or anodized gold, black or any other painted colors).
Caliper mounting bracket with high tensile steel studs.
DOT stainless steel braided Teflon brake line.
High performance sport brake pads (race pads are optional).
90% applications retain OE parking funcation.
Minimum of 15" rims in order to clear this brake kit
For vehicle compatiblity, kindly click on: http://www.xyz-racing.com/brakekit1.php
2. 6 pots with 303mm rotor
2-piece 303mm x 28mm slotted rotor x 2pcs.
Tool kit x 1.
Features:
Rotor thickness 28mm.
Minimum of 16" rims in order to clear this brake kit
for vehicle compatibility, kindly click on: http://www.xyz-racing.com/brakekit2.php
3. 6 pots with 330mm rotor
2-piece 330mm x 32mm slotted rotor x 2pcs.
Tool kit x 1.
Features:
Rotor thickness 32mm.
Minimum of 17" rims in orde to clear this brake kit
For vehicle compatibility, kindly click on http://www.xyz-racing.com/brakekit3.php
4. 6 pots with 355mm rotor
2-piece 355mm x 32mm slotted rotor x 2pcs.
Tool kit x 1.
Features:
Minimum of a 18" rims in order to clear this brake kit
For vehicle compatibility, kindly click on http://www.xyz-racing.com/brakekit4.php
Rear Brake Kit:
1. 4 pots 286mm rotor
4-piston caliper (painted red, yellow or anodized gold, black or any other painted colors.) x 2pcs.
Tool kit x 1.
Features:
Squeeze forged 4-piston caliper (painted red, yellow or anodized gold, black or any other painted colors).
Minimum of 15" rims are required to fit this brake kit
For vehicle compatibility, kindly refer to http://www.xyz-racing.com/brakekit5.php
2. 4 pots 303mm rotor
Tool kit x 1.
Features:
minimum of 16" rims are required to fit this brake kit.
For vehicle compatibility and more information, kindly click on http://www.xyz-racing.com/brakekit6.php
3. 4 pots 330mm rotor
Tool kit x 1.
Features:
Minimum of 17" rims are required in order to fit this brake kit.
For vehicle compatibility and more information, kindly click on http://www.xyz-racing.com/brakekit7.php
4. 4 pots 355mm rotor
Tool kit x 1.
Features:
90% applications retain OE parking function.
Minimum of 18" rims are required in order to fit this brake kit
For vehicle compatibility and more information, kindly click on http://www.xyz-racing.com/brakekit8.php
330mm rotor brake kit installed:
Comes With full set including rotor, caliper, bracket, steel braided hose and installation manual:
Brake System Kit FAQ
1. Does XYZ brake kit have any warranty?
XYZ caliper has one year limited warranty.
2. What’s the difference between Sport pads and race pads?
Material, friction, brake force and working temperature are different.
3. Is your caliper CNC machined or cast? Do they work with ABS?
Our caliper is forged with finest aluminum material, than we CNC machine bolt holes precisely. They can work with ABS.
4. If my brake pads are worn out, can I use other brands to fit on your brake system kit?
Yes, you can purchase the brake pads from the following well-know brands like AP, FERODO, EBC, HAWK … etc to fit on our big brake kit.
5. If I want to install XYZ big brake kit, is any modification on my car required?
With our design, you can just install XYZ big brake kit on your car without any modifications. However, in some rare occasions, the modifications are required to fit our big brake kit.
6. What direction do the rotors go on the vehicle?
The right picture shows you what direction the rotors go on the vehicle.
7. I am afraid XYZ 6 pot caliper can not fit on my vehicle?
The specification of XYZ 6 pot caliper is same as that of AP 4 pot caliper. But its width is slimmer than width of AP 4 pot caliper, the edge of our caliper does not touch the rim as far as possible.
8. What pads do fit in XYZ front and rear calipers
9. Does XYZ brake kit can fit stock wheel?
Whether XYZ brake kit fits a stock wheel depends on applications. But our 330m/m rotor requires a minimum 17†wheel size, and our 355m/m requires a minimum 18†wheel size.
10. When do I change the brake rotors?
Check regularly for any cracks, deformation or warping and if so, relace it immediately. Rotors should be replaced if any faults are discovered or if the rotor has worn below the minimum thickness of 1.0mm.
PM ME OR EMAIL Me AT [email protected] FOR BEST PRICE OR ANY ENQUIRIES!!!!!!!
Thank You!!!
XYZ Auto Parts
Front Brake Kit:
Tool kit x 1.
Features:
Tool kit x 1.
Features:
Tool kit x 1.
Features:
Tool kit x 1.
Features:
Rear Brake Kit:
Tool kit x 1.
Features:
Tool kit x 1.
Features:
Tool kit x 1.
Features:
Tool kit x 1.
Features:
Thank You!!!
I think everyone is interested to know the indicative price for the brake kt!!! Not necessary need to b the real price...
