No doubt big rims, wide tyres equals to good highspeed grip and good emergency stopping.
The thing u have to come with is BIGGER rotors n calipers, better brake pads and better brake servo.
The question is, DO U NEED 17" for your car ? No, unless factory OEM stated into your manuals. I would say some ppl sacrifies EVERYTHING just for good looking of thier cars, that I have nothing to comment.
One more thing, bigger rims, heavier rims means using your stock braking system is PUTTING YOURSELF INTO DANGER. The stock systems are NOT meant to stop 17" in time, its very risky if u were driving in the rain suddenly u need to jam brake, your small OEM rotor will NOT have enough braking effiency. Its either u cant brake in time, or u LOCK ur front tyres resulting skids.
Imaging putting lorry tyres into your car, ridiculous isnt?
i change from Rim 14 steel rim with 185/65/R14 to 15 alloy rim with 195/55/R15 so the outer diameter of the whole wheel is still almost the same therefore i wont suffer any acceleration.
Yes you are right,FVel.
But larger daimeter rims is like altering your gearbox ratio. Suppose your gb ratio is build to power 13"-14", but up put a 17". What will happen to the powerband and torque from your engine to your wheels ? It put alot extra stress to the engine, thus every wear n tear parts will KO much faster.
There's always a limitation to the size of the rims that your engine n braking system could take, unless u upgrade both aspect, then you go for bigger rims.
Eg:
Stock Wira 1.6 is 14" rims. After upgraded to GSR turbo, after changing bigger rotors n calipers, u need more grip to hold n the road, then oni u go for 16".
What will happen if u drive a myvi with 17" beside a Turbo-ed Car with 16" ?
I promise u the turbo driver is laughing the shit out of his life !
