4g93p Quad Throttle
buyunica
guys need ur advice bout dis kind of modd...i need 2 know either i can use standard ecu?? or hve 2 switch to piggyback or standalone to suit this mod...n im lookin for 4g92 cusco headers...thanxxx...im really dumb bout electronics...:)
u can't use back ur ecu if ur going for 4 throttle.remember,ur car uses maf
sensor to calculate incoming air not maf.u need standalone to convert ur
engine from maf to map.
i saw my foreman done one 4g93 use 4 throttle using safc + ecu ori.
and now my friend's mivec is doing the jobs too but using black top one.
so should can be done but not as smooth as the single big throlle unless use the Better ecu to tune.
People always use toyota throttle to mod in as cheap.
If not wrong silver use maf
black use map
correct me if wrong
If u have the heart to play 4 throttle, my advice is get a standalone management!
u can run with standalone or without standalone also
condition is, if u run with stock ecu , u musttttt create a custom intake manifold and secure the 4 throthles and then run the air flow
mivec owners are diffrent, u run on MAP sensor n not MAF :P
why must create custom intake manifold??... so u can use MAP to give signal to ecu??...
just put the ECU on the floor, get a screw driver to tune ur card...easy job...ahahaha...:biggrin::biggrin::biggrin:
sifoo :adore: :adore: :adore:
no.what jin mean is that built a plenum over the 4 throttle so u can run
maf.like in the pic.
https://www.zerotohundred.com/forums/attachments/127083.vB
while the outside look like this.
https://www.zerotohundred.com/forums/attachments/127084.vB
u got the idea when u look at ae111 engine.the 1 with 6 speed.
something like this??...
http://aycu30.webshots.com/image/34069/2005159286645400315_rs.jpg
but this is carburetor la... kekekekeke...
