i know...
if wanna oversize.. might as well hit bigger..
here i see all hittin real big.. 84 above..
but not toyotas..
toyotas wit type r pistons also i've seen b4..
benjaminn, this is a off topic.
may i know did you suffer from aircond on idling problem with 272? and emanage feature "anti engine stall" can solve the problem?
..but 300 cam sure have problem with aircorn.....
if i am not mistaken 4agze bore and stroke also 81x77 rite..so means tat if i wanna turbocharge my bt i also cna use CA18 piston rite...anyone can tell me ??
if now i wanna use 82.5 piston wat car should i use leh....
i saw b16b type r piston is 81x77.4 mean the bore is same..can i use it???
coz that piston is 4 valve and ours BT is 5 valve i scare hit the valva...anyone know also ??
