Can 15" rim with pcd 100 and 35 offset fit well in EG
cat77
Onyone can help???? or any comment.....thanks
I think can...my current rim pcd100 15'' offset 35 previous owner used 'em in his 2dr EG....mayb depends on rim design also, best is to test it on the car directly...
depending on the width of your rims.
15"x6.5" offset 35 should be no problem. Tested on both DC2 and EK9.
15"x7" offset 35 will fit the front no problem. But you will have problem on the rear unless your car is not lowered or if your suspension is very hard. Otherwise the rear normally will touch the fender in hard cornering.
Shouldnt be any problem...I'm using 15X6.5 offset 32 with semislicks all round.
Im using white CTR rims with 205/50/15.. no rubbing anywhere.
But I'm not sure exactly what offset they are... either 35/45 (>_>)
need help.....anyone know market price for 15" ce28 rim???? thanks
Write your reply...
