Oil Cooler
pathfinder
Hi
Where can i get aftermarket performance oil cooler & ATF cooler?
How much estimate ?
What brand?
Thank u
what car you're drivin' dude?..
i got my Blitz oil cooler for RM1.2k..its for RB's btw..
fuuhhh
Blitz???
cannot. me only drive volvo S70 low pressure turbo..not a performance car
need extra ATF cooler to prolong the auto gbox life
around rm5XX to RM1XXX brand new ...
depending on the brands?
just the cooler.adaptor u can find it at motorsport shop or fabricate it urself.
since u drive a satria with mivec engine,there's a lot of o/cooler adaptor for
ur application.
if u look for oil cooler, i can introduce 6 row mitsubishi pajero half cut including adaptor + oil roughly RM6xx
For engine lubrecation Oil when moded with a cooler or to a larger cooler, the oil pump is also modded to compensate for drop in oil pressure.
In ATF case, you can't mod the pump (AFAIK).
Therefore, make sure you guys check the before and after ATF pressure.
Adding too big an ATF cooler will prematurely kill the Auto slush box.
PS : pressure drops symetrically with the cooler size increament and ATF under too low temp. will not lubricate ideally
is this considered oil cooler??..
http://img378.imageshack.us/img378/9772/oilfiltercooler1nh9.jpg
http://img378.imageshack.us/img378/4418/oilfiltercooler2su2.jpg
i've been looking for this item for quite a while now sky.where do u get the
pic?is it local made?i know it wont dissipate heat as good as oil cooler but
at least it lower the oil temp slightly.i know they sell it in taiwan but not sure
whether anybody bring it to m'sia.
dunno ler.... last time copy from dunno what website... kekekeke...
if got let me know ar... i also want one...
just talk to my supplier just now.show him the pic that u attach.he said
in china got.i ask him to bring it in.he said ok.once i got it,i'll let u know.
cheers.....:proud:
hehehe....bling?nevermind lar.as long as it work.summore u mount it on the oil
filter at the block so nobody see it.:)
cheers.....:proud:
whats the price range??.. if cheap cheap can lar.... coz i dont think got serious improvement in cooling compare to a proper oil cooler...
i think not even rm90.i think it's cheap only.just a heat sink.
