Need Help for Buying A32
weikee
924
15
when i see car, i look at body first. and if thats the car the condition are not so good on the body.
maxiro
210
very bad ar bro about the body? what about the engine?
weikee
924
15
i am not sure, buy this look like the same car i see about 1 month ago. I'll only check on engine and g.box after pass my body QC :)
You need to send your mechanic to check the body if you are not good at checking the body. Body its the most important in the car. Engine wise still can change. For Korean car, everything are important cause engine and g.box are rare.
maxiro
210
if i am lookin for used car, i would get it from its owner rather than used car dealer...hehe
any luck yet?
susah mau dapat from owner himself...no luck la ong, maybe next time...
weikee
924
15
normally buying Japs used car body number 1, than engine & g.box.. cause most japs car can find engine and g.box. Korean car you need to make sure body, engine, and g.box good condition.
you got to look at the joint, weld, curve, boot, rear spare tires compartment, curve, paint, glue / rubber sealant, undercarriage, firewall weld on the structure (if front impact are serious, structure may go deeper into firewall) . try see few more identical car, you will know the difference.
don't look at the car on the outlook, outlook internal, under.
maxiro
210
soon i'll take a look around of that area...tq weikee...
hi bros
im driving a satria with 4g93p bolt on turbo
my prob is...when im revving at ard 3-3.5k ...there is this weird wongg wonggg sound occurs....it doesnt matter whether im in 1st 2nd or any gear...the sound will occur at that rpm...when it passes the 3.5k mark, then everything goes back to normal...
2nd prob....my engine oil i checked....it decreases to minimum level after travelling only for about 1k km....i dun see any leakage or what so ever....
plz help!!!:wavey:
