- Joined
- May 10, 2007
- Messages
- 23
- Points
- 1,501
Looking for Car Alarm ?
Package
1 x GSM Unit
1 x Alarm Unit
1 x Immobiliser
1 x Siren/Loudspeaker
1 x Microphone
1 x GSM Antenna
1 x LED
2 x Remote Control Key Fobs
1 x Auto start device.
Connecting Wires
1 x User's Manual & Wiring Diagram
Functions and Features in Details
Uses GSM Network
The alarm is fitted with a mobile telephone SIM card (not included), allowing the alarm to make and receive telephone calls. This also allows you to track the location of the car via the telephone signal. Any SIM Card can be used . You can monitor your car anywhere in the world!
Easy to Use
To use the system, just call the telephone number of the alarm, enter your pin number and a voice menu will guide you through the options. The pin-number system prevents unauthorized access to the alarm features. Calls can be made to the alarm from any telephone.
Telephone Alarming
Three alarming telephone numbers can be registered on the alarm. If the alarm is triggered, the alarm will automatically call the first telephone number within 13 seconds. This is in addition to the regular alarm (flashing lights, siren). If there is no reply, it will call the second number. The user can then reset the alarm, monitor the car, send a verbal warning to the burglars or immobilize the car all from the telephone.
Panic Button
Two emergency telephone numbers can be registered on the alarm. It is advisable to set these numbers to close friends/relatives. If you are in trouble - hit the panic button on the remote and the alarm will automatically call the first emergency telephone number. If there is no reply, it will call the second number. The user can then reset the alarm, monitor the car, send a verbal warning to the burglars or immobilize the car.
Remote Arm/Disarm
The alarm can be set using either telephone or the remote control. If the vehicle is fitted with central locking, this action will also lock/unlock the vehicle. If the alarm is set by telephone, then the alarm cannot be unset by the remote. This feature has many uses:
Someone needs to get in your care when you are away
You aren't sure if you locked the car or not
You lock your keys in the car
Someone steals the remote & keys - if you lock via the alarm, they will not be able to open or disarm the car with the remote
Remote Status
Call the alarm at any time to check the status of the vehicle.
Sms function
This alarm set have sms function.
Remote Monitoring
A microphone installed inside the car allows you to listen in to what is happening inside the car from your telephone. Thieves in/around the car will be completely unaware that this is happening.
Remote Broadcasting
By calling the car alarm, it is possible to broadcast your voice through the alarm loudspeaker. This can be used to give a warning to anyone near or in the car.
Car Location
You can track for your car location using gsm service provider to know your car location.(example like maxis friend finder service.)
Anti-tamper
The unit has a backup-batter which works for 7 hours. If disconnected from the power source, the unit will immediately call the registered telephone numbers to warn of the situation. The unit can still be traced during this time.
Anti hi-jack
In the event your car is hi-jacked - do not fight back against the hi-jackers. Instead, let them go and then initiate the anti-hijack feature by calling the alarm from any telephone:
Hazard lights will flash
After 10 seconds the hazard lights will start flashing , After 20 seconds, the alarm will start sounding and hazard lights will flashing, After a further 30 seconds, the car ignition will be cut-off, the vehicle will then be completely immobilised
The alarm will then sound continuously.
Car Locator
Pressing a button on the remote will cause the hazard lights to flash and the alarm siren to sound for 3 seconds. Just in case you can't remember exactly where you parked it !
Silent alarm mode
The silent alarm mode works just like the regular alarm settings except that if the alarm is triggered, the siren does not sound. Instead you will receive just the telephone call warning only.
Auto Hazard Lights
If any door is opened whilst the engine is running, the hazard lights will immediately start flashing. This is useful to warn other motorists that you are stationary and moving around the car. It is also useful when you have children in the car, if the door is slightly ajar, the hazard light signal on the dashboard will bring this to your attention.
Technical specifications:
1)GSM frequency: 900MHz and 1,800MHz
2) Voltage: 12V
3) Temperature: -20 - +65°C
4) Control distance: 20m-100m
5) Remote frequency: 315-316MHz’
SONY ERRICSON MODULE WITH ANTI-HACKER SYSTEM PROGRAMMED
P/S: Im sick n tired of those ppl calling me to show demo and finally ended up, it's too expensive or i will decide later, its jus wasting my petrol and time, Read the function 1st if u r serious buyer i will show d demo,U can use prepaid/postpaid number, Price Rm980, Installation Rm180
Chipset: Sony Erricson support GSM not PCN
Reseller: Yes u can resell it as i remove the label for u to resell it.
Defective: If the module has manf defects i will replace it for u with labor at no cost, but so far all my customer never complain b4
Remote Start: now i cant promise u this part if ur ride has built in immobilizer, u need to fix extra device to activate tht which will cost u less thn rm200, for my bimmer i modified the remote start so it can syncronize with my built in immobilizer,
If u feel other shop/brand givin u cheaper pls go for it plz dont compare it and ask to reduce for d price
Contact: 014-6227766 or [email protected]
TQ
Package
1 x GSM Unit
1 x Alarm Unit
1 x Immobiliser
1 x Microphone
1 x GSM Antenna
1 x LED
Connecting Wires
Uses GSM Network
Easy to Use
Telephone Alarming
Panic Button
Remote Arm/Disarm
Remote Status
Sms function
Remote Monitoring
Remote Broadcasting
Car Location
Anti-tamper
Anti hi-jack
Car Locator
Silent alarm mode
Auto Hazard Lights
2) Voltage: 12V
TQ
