Water in Headlamp
evoace
There is water in headlamp?
How to get it out? Any shop specialise in this?
Tks
1st of all.. what car are u using now??
It is very easy to get it out onli and u can DIY it your self also no problem..
Take out the pin at the side of the headlamp then wipe it with clean cloth...
After wipe it... using silicon glue to glue at the side to block water from entering it...settle...Good Luck...
there is another way without removing ur headlamp cover.... remove ur bulb, expose the hole under hot sun... few hours after all water vapour evaporates away, replace back ur bulb lo...
make sure the lubang faces the sunlight so the water vapour can escape upwards....
evoace,
Before removing the water, there's a few questions you first need to answer.
1) How much water is inside your headlamp?
2) Are there any fishes or water living creatures that has gone into your headlamp to live in the water?
Once you provide me the answers, I will then advise you on what to do next.
evoace,
There is no fishes la...hahaha
Just some water vapour. dont know how the water can get in. It's a toyota camry 4 yrs old.
Can you help?
with a head light so big,i don't think is ez to rip it a part.if u do manage
to open it,make the side reflector black la bro.damn nice for camry.
yes, it is not easy to take out the headlamp too, you have to dismentle the bumper in order to do according to the manual.
However the water vapour has disappeared..:) but scare it will come again
