HELP! Car overheating..
VMK77
Hi everybody,
Need help.. my car is overheating it's a wira 1.5 carburated engine. Did an overhaul (Full) after white smoke started coming out. Just did it about a week ago. My mechanic says it's the motor oil type I should change from 10sae to a 20 sae or something like that. Everything is fine for about 20 to 30 mins but after that the temperature rises gradually to almost the red line. I've tried flushing the radiator, changing the termostat, changing the hoses, changing the fan but nothing seems to work. All this done in the past week. Change engine?
Anybody can help me? :retarded:
radiator leaking? try checking it wit coloured radiator coolant. maybe a leakage sumwhere
I check the water pump already.. Damn OEM parts.. cost so much.. and already bocor after one week!!!! Any suggestions? I mean ca use any other brand ke?
Thanks to all.
Thanks to all.
usually the most popular water pump replacement is GMB.cheap n reliable.try n ask the autoshop
for it.
Thanks to all.
mayb while replace the new water pump, they no remove the gum at the block there nicely
I overhaul in Likas.. Going to get a halfcut.. Please PM me for best price lah taikor.. also interested in your grounding cables man..
Lolz.....i asked u to find me ma...since i stil at kk....hard to pm price for halfcut as im not from chopshop...and i dunno wat u wan.
price is different la bro...u wan engine only, or with halfcut,...etc etc.
if u wanna go for halfcut, i wonder y u wan to overhaul...it just waste of money.
if u r really kind in transplant, u can go survey in any chopshop in kk.
once u confirmed wit the halfcut, u can let me know. we will get for u.
Aiya.. only one car mah I have.. have to do it lor.. cannot take bus to work.. 12 years oledi no use bus.. I want mivec half cut.. how long you do conversion?
its good if u go to see the halfcut by urself...so u can choose, u can test.....once u confirmed then only sent to my place...if i choose for u, later got problems...dunno gotta blame who..
try Ah Ming autopart, Desbil, Tilija (rare).....get the full halfcut is great :_:
if u cant find one and u really interested in mivec, then i can order for u with minimal deposit...
conversion maybe 10days like tat....(depends) as having many cars to do most of the time....
Definitely want to do already, wait for some money 1st. Damn car overheating. Do everything already.. Spend more money than buying half cut...I contact you once got some money..
