Wah.. ur engine quite good lor.. i got at 50km.. sighdis u gotta go to a workshop wit dis device.it checks ur compression,duh.hehe .mayb ur pistons rings r worn off.or a crack in ur pistons.or u might need 2 rebore ur block...change new pistons...
its done by yesterday with result at 9:1 and someting he said about ??bar (blur)..
the pomen said its come from my block or head but he not so sure..you say like your engine gonna fall apart.. maybe the problem is not with the engine head.. with the engine block..
Need to check again by end of the week bcoz need extra time checking for sure..
already try to tuning by computer but their said my ignition timing problem and under power..check ur GB...gear ratio sometime cause this kind of problem...
thus check ur ECU....
metal gasket on N/A car?? wht a waste..
Good Luck..
gear ratio?? no idea
metal gasket is recommended from zth forummer.. i just try it out bcoz of this problem.. Do u have any idea is its not good for n/a car?
[/URL...
