- Joined
- Apr 18, 2006
- Messages
- 3,677
- Points
- 1,663
Well, it's better than the 2618 Al, so that's a relief.Even when you use a 4032 alloy piston, you will still need to warm up. Its quieter than 2618 but is still noisier than OEM. Piston to wall clearance are in between OEM and 2618 alloy.
The true 4032 alloy piston manufacturer which design them in strutted and very ligthweight type are commonly making pistons for F1, BTCC, WRC, MotoGP, aeronautical etc. To name a few are Cosworth, Omega, Accralite. To a search on these and you will find them all costing above USD$1000 for a set without rings. hehe..
I know..But aren't these around the same price range as well? Ka-Ching!
Does this mean that the set in this pic is the 2618 Al? since you said that most Japan manufacturers use 2618 Al? In that case.. 2618 is definitely still unacceptable for me for a daily driven ride. Some people find it acceptable, because they don't drive their cars often.. but for me.. errr.. not so much.
And since the 4032 comes with a premium price tag (depending on how much I can get the units for).. well.. looks like I might have to adjust my plans for a forged set or go R and limit my horsepower target a little.
USD1K++ is, That's a huge chunk of change out of a modding budget :P, considering I can get a lot of other stuff for that price point. But considering JDM units aren't that much more cheaper.. depends on what my budget can fit in. I think Cosworth would be nice, if they're within 5K or so. My friend also particularly likes that brand, but the last time he got quoted some insane price that put him of permanently.. :P
But looking at the cosworth site.. the piston for the caterham is now retailing at USD899, the 4032 type.. but the short skirts are a bit worrying though, but custom specs means can get around that.. and they're custom made to order, which usually means long wait times and 100% deposit.. have to send specifications and stock piston and pin too. Ouch!
But they might be cheaper though, but I'll wait until I have cash in my hands before I even ask for a quote.. I expect lower than 1K though (hopefully they have done this before and has the die to do it, that should get me a reasonable quote or else I'd be looking at an insane quote again), and I'm not sure if my friend will agree to my choice, if I do make it.. but looking at it, I'm expecting I should get the block and engine specs down pat before deciding on something like that, because from their form.. they require those specifications as well.
Since it's for personal use, it's not about making every single horsepower out of the engine.. more like a daily drivable powerful ride that runs reliably (and CONVENIENTLY) at it's limits.
So much for limiting budget for engine mods.. (X_x)
And you're not the only one that says that about JE pistons.
