Fixed New Thread missing Editor: Hi Everyone, the issue with posting a new thread or a reply that shows a missing editor has been fixed. More updates to the forums will be added on in the coming days, we apologize for the inconveniece this has caused
Anybody have experience with tyres, for 17" wheels to be exact. at present i'm loosing the rear end quite a bit on full throttle. Brands and sizes suitable for 9 inch wide wheels preferable.
Semi-slicks Dev? I'm assuming it'll be 'reasonably' okay in the wet if you baby the throttle along.
Advan A048, Dunlop Formula D01 and if I'm not mistaken, Silverstone has one used in the Class C cars of MME races. Can't quite recall it off the top of my head at the moment, and I'm not too sure regarding sizing.
I guess with 500hp.....u gotta live with being a little loose at the back end. Unless you use drag tires.....nothing will actually guarantee grip. My old S13 with only about 275hp at the crank.....still that back end kicks out. Heh! Heh!
i like my 17's.going up to 18's or 19's might cause some serous rubbing.
Need to get good tyres before i start turning on water/alky injection and turn up the boost higher. trick to good engine is not to ut corners.
Go with a set of B'stone S-03s Dev. Can't say I ever had 500 horses but personally loved the S-03s on my RX. Excellent in the wet and dry. Get them from Singapore as they are about 1/2 price after conversion unless you can find a good used set here. :shades_smile:
that's what i heard... tyres are freakin cheap in Singapore....
buy pirellies in SG then :) ...
So3... herman was using it.. he got it 2nd handed... but still pretty pricey with a 85% SO3.... going for RM 400 per piece....new ones are not easy to find due to their availability going at around 1K per piece.
i have Proxes on me as well.... T1-R... reasonably priced... good grip as well...
but i'm not too sure if it can take 500 horses... my size 225/45 R17 only going 380 per piece... gotta change at klang... if you decided ... i believe you better to book first. they might not have all the size... and you'll ended up waiting half day for the tyres to arrive like what happened to me...
I remember around 630 or 640 per piece for 265/40/17.. For 500 Bhp i guess T1-R still throw u a bit to the left and right during full throttle on 2nd and 3rd gear. I do not really recommend T1-R as i am using myself.
i'm considering getting an evo 7 and would like to check if anyone knows the history of this car. Its a black evo 7 bearing no. plate BDA 19. It looks reasonably stock externally and internally.
another pop up question on this car.
Previous i post on celica.. asking on opinion...(bad)
about silvia.....(nice)
and now want to ask about skyline..
so i am new be here...
for the time...
I knew this was gonna happen someday... and it just did.
My power steering went kaputt (The P/S Light is on). Even before this, my powersteering comes on and off (without trigerring the P/S light). So my question is...
