Chris,how about Brian Crower cam?
What about them?
Hi Sifus,
I don't want to open new thread. I think it will be okay here. If I used CTR cam, what others part should I change too??? Furthermore, what kind of setup that i need to do when change this CTR cam? I heard that, B16A engine will be more responsive if used B16B piston (conrod used B16A) + CTR Cam. Is this true??? gain more hp with this setup? TQ in advance.
CTR cams at least CTR/ITR valve springs.
B16B pistons are not such a great combo in B16A block though i have seen them done many times. Compression is way too high for a daily drive and you defenitely need some sort of ecu to tune fuel and ignition.
Your mech must know what he is doing, cause in a B16A block the B16B piston will sit higher than the block and either the rod or pistons have to be modded to fit. And cylinder head also needed to be modded to get them fitted. Not a simple plug and play.
Eh? Isn't the common setup be thicker/dual layer? gaskets (if head is milled b4), then the valve reliefs in the piston also need to be milled for valve clearance and the rods need to be shaved on the sides on the piston mounting rod ends (where the wrist pin goes through the rod) to fit B16B pistons? Truly not plug and play setup, but not a truly major work to get them fitted. I think final combustion is still around 11+ there abouts, but dependent on gasket thickness and if the head has been milled before, I think. Also that setup will definitely need tuning, as you said
I don't think combustion chamber need to be modded, but could it be perhaps I might have missed this?
I'm also learning, you see.
Of course, for the cash modding it, I think there's much better ways to gain power, say with a better exhaust system, for example.. or some other part.
The mech has to do combustion camber work to get this B16B piston to work.
You mean for 9K setup or stock setup? So does that mean it's a necessity for the combustion work, or no?
My car got problem..
