I havent put it back.
Thats the original pin since 2008.
i know its suppose to move in and out but it can move up and down left and right. Is the other movement instead of in and out are normal or should i replace?
Replace it if it's moving that much. But you need to test it with grease, not greaseless leh.. The problem with the silicon o-ring type is you grease need to do it nicely. Can't put too much because it'll compress the grease making the caliper hard to move and then braking failure
Just bought this replacement pin with silicon. Ori replacement only left 1pc.
Already install right side after smeared with bearing grease, play with the pin by pushing it in and out then smear again.
RM75 for a set. After dinner will install left side and hope no more sound. If still got then i am lost as already check the arb bush and lower arm are all in good shape. no loose bolt or freeplay.
Shit....noise still there despite the improve pedal feel.
When i drive just now i had the window down and notice the sound when i turn the steering at stationary..Its the damn steering rack bush.
Reactions: leinnz and Izso
leinnz
333
57
3,028
so culprit is steering rack
The steering rack bush to be exact.
Its not worn out to the point the rack is moving freely. Its in a way still holding the rack firmly until a point it gives by making the rack moves suddenly in few short amd sharp movement.
kinda hard to replace esp the passenger side due to P1 bad design of having the aircond drain pipe above the nut of the bracket. Its rusted almost beyond recognition.
parakey
1,367
226
Is the BLM's rack bush similar to the one on the Preve? I hear FB group people frequently complaining about it
That one i dunno. The ori one i just bought only written BLM on the box. Will try to remove the rusted nut this weekend.
Last time with waja i encounter short lifespan of steering bush. A tire shop notice my loose bush while doing allignment and told me to put a short timing belt or aux belt cut to make it tighter and last longer. I did that and it works. I used abt 1 inch a piece at both side.
parakey
1,367
226
MY tyreman did the same for the Wira's lower arm bush
Thats new to me. Normally new lower arm with new bush are a bit harder to fit in esp the end with that square bush end thus it fits in a snug manner. BTW my bro mentioned that the correct way to install lower arm is to fully tighten all bolt/nut when the car is at its resting position. This is near impossible to do at home unless we have a hoist. Its done to ensure normal lifespan.
parakey
1,367
226
Was some years ago. While doing alignment, he noticed the bush was worn. He took a some rubber tubing and clamped it together with the bush. I left it like that for years.Kinda silly since those bushes dont cost much.
I read something like that before but have yet to see any mechanic do it. I think this is only something you can do if you have one of those lifts that raise the car with the tyres resting on it. Tyreman's alignment lift or the tunnel they dig in the ground
Hi, need your help gurus. I just bought a evo3 tb from a guy in jb for my lancer 4g18. I know it's plug and play as quite a number of ppl in Singapore has changed their tb to bigger one from evo3. But the one I bought comes with the stepper motor or uou call it isc from a 4g93NA. Will I have any problems with installing it on my engine ? If yes, where in jb can I buy the isc which can be used with a 4g18... ??
