Airtrek Turbo Wheel-hub bearing
biao
348
24
perak / ipoh
Hi Sifu,
did any one have change the wheel-hub bearing before?
how much the cost change the new one?
not airtrek...but other car...
just check what bearing code....buy bearing and sent the hub to machine shop if need pressing...
i guesstimate bearing for airtrek about rm130-240 for 1pcs depend on what type of bearing used...
biao
348
24
perak / ipoh
can do like this? i saw the halfcut shop used unit is complete with hub and the 5stud together, bearing is conseal.
definately yes...
thats how bearing replacement is done...
depend on bearing type...
either this
or this type
the latter is much easier...just remove everything by screw/bolt and replace...
biao
348
24
perak / ipoh
definately yes...
either this
or this type
i think ours is 2nd type right.
steven_323f
54
9
1,508
BM,Pulau Pinang
I prefer go workshop and ask them to exchange new bearing will do.
Front pair is around RM300-RM400, different brand different place price will different, i just change mine last month.
biao
348
24
perak / ipoh
hi, our airtrek turbo is using which type? your foreman help you change which 1?
buy a bearing to press in replace or the whole wheel hub type?
steven_323f
54
9
1,508
BM,Pulau Pinang
I didnt not know, i leave to my friend to settle it.
They will take out from your car as sample, and find same size to fit in, about 1 day jobs only.
Oct 19, 2017
4
35
For vehicle using rear hub bearing assy such us toyota camry, the average cost to replace the part is between $400 – $500 for one side, labour between $100 – $200 for one side.
biao
348
24
perak / ipoh
are you sure that costly? but i don't think so.
RWD can cause the car to have more oversteer and AWD make the car to have more understeer when coming to corners
Even Nissan GTR R33 & R34 in Japan GT is modified to RWD with wider tire in the front at is 330mm while car like Enzo FXX front tire is only 255mm or 245mm
But RWD are more likely to spin in corner if throttle is applied, will be harder to turn a AWD as will cause understeer
The reason AWD doesn't spin out that easily is because some percentage of power is transferred to...
