Ok la, he surely can afford Hankooks what!Now see his budget loh..........
He buying so up to him......hehehhehhehe......Ok la, he surely can afford Hankooks what!
The V12E2 should be much better than the Nexen. That tire goes up against those top line Goodyear F1s, Michelin PS series, CSC etc2 and able to match or even beat them on occasions at fraction of the price. If that online quote gives rm300, then if really ask around shops, you might get even cheaper and matching the Nexen price already.Hankook V12 I was told was RM300 a piece. Mytayar.com is online shop, still need to pay a bit to have them installed so RM300 is average price.
Almost bought the Rovelo A1 Sport, the supposed top-of-the-line Rovelo tyre range which isn't really much to shout about for RM230 a piece excluding the tube (rubber RM5 a piece). But after some discussion I ended up with the Nexen AU5 215/45/17
Regret like hell.
Soft sidewalls means a 5% improvement in comfort (which isn't much), it's noticeably softer but not significant enough for the family to notice. What I personally notice is how it affects movement of the car. I notice the response time to accelerate and brake for the tyre is slower compared to my Goodyear Assymetric2 tyres. Fail la. Next time I'm buying hard sidewall tyres. Screw comfort. 5% not worth the RM288 per tyre I paid in the end (including GST).
I'm also guessing I won't like the V12 as well since it's a soft sidewall tyre too. But grip wise the AU5 is quite good in wet and dry, not as good as the Assy2 since I'm hitting the limits of grip much faster but it does grip quite well. Comparing the AU5 (RM288) with a RM460 tyre isn't really fair I guess.
Must work harder so I can afford better tyres in future. Oh and all 4 rims need minor repairs. Not affecting the balancing but all visibly bent a bit. Sigh.
Dammit.
He should've bought this GT Radial HPY if want stiffer sidewall right?You get what you paid for loh......hhahahhahahha
Like my GT Radial HPY, at that time 340 against Asy2 460, the grip in dry and wet is pretty good but 70 to 80% to Asy2 performance so to pay 340 about same as you get what you paid for.....hahhahaha
I was about to poison him with the V12E2 but he back out last minute and wanted something cheap below 300. So I say Rovelo sports A1 is the cheapest at 230, mana tau he choose Nexen for more comfort....hhahahhaThe V12E2 should be much better than the Nexen. That tire goes up against those top line Goodyear F1s, Michelin PS series, CSC etc2 and able to match or even beat them on occasions at fraction of the price. If that online quote gives rm300, then if really ask around shops, you might get even cheaper and matching the Nexen price already.
Btw for you is the F1 sidewall also feels soft? Coz manny of those top UHP tires also considered to have somewhat soft sidewalls like the F1 & PS3.
How come all 4 rims bent already leh? Then you need thicker tires actually. Want to buy my 17' Prodrive? I'm thinking to switch to 18'...
---------- Post added at 05:11 PM ---------- 6 hour anti-bump limit - Previous post was at 05:07 PM ----------
I'm using 36PSI right now and no. Rovelo A1 Sports is hard sidewall.Pump 40PSI !
Rovelo sports A1 sidewall is soft too right?
You need performance tyres lah! Cannot go for cheap comfort tyres.....lolProdrive rims? Those aren't PCD100 x 4. Can't la.
And V12 is soft sidewall, I've driven a car with it in the past and I wasn't too impressed or disappointed. But different size means the impression isn't really accurate.
Assy2 sidewall imho was hard. Not as hard as the RSR, but hard nonetheless.
And I'm becoming increasingly annoyed with the slow response from the tyres everytime I accelerate. It's bad enough the CVT is rubber-band-ish and now it's further held back by these tyres. Ish.
Hard sidewall with correct pressure against soft sidewall with high air pressure is totally different.Pump 40PSI !
Bro., 40 series what soft sidewall you talking about.....hhahahhahahahhaAhhhhhh...V12E2 soft side wall ah??? No good ah??
Previously had a long talk with bro VR about this. Got my mind set on the V12E2. Now i read this....Back to my indecisiveness state.......HOW LA?!?!?!?!:frown::frown::afraid::afraid:
Looking for 235/40/18. Klang quote me RM350 per piece for this size.....
So any other recommendation?
And can anyone share how do you know if a particular tyre has soft or hard sidewalls??? Any indication or numbering to look out for?
RE-S001 are max performance tyres like RE-050, RE-S03 and 04 pole position, but whereas RE-070 are extreme tyres, same as RE-11 or Yoko AD-08, so they are of different class.What about Bridgestone Potenza RE070 225/40R 18" or Bridgestone Potenza S001 225/40R 18"?
Handles the corners very well and nice to drive high speed during dry weather. Need to be a lil bit cautious while driving during rainy weather. Of course gotta compromise between comfort and handling. Been looking for these but can't find it anywhere around the Klang Valley area.
Changed to Bridgestone Potenza S001 a few years ago and handles the corners quite okay but not as well as Bridgestone Potenza RE070. Got a stiff sidewall but not as hard RE070. Not bothered about comfort since I'm more worried about handling.
Had it replaced with Nitto Invo a year ago. Big regret on buying these tires. No choice that time because of budget was tight that time.
Looking for tires that perform like Bridgestone Potenza RE070 right now.
40 series means you will have thinner sidewall, lower profile. The lower you go sidewall needs to be harder to prevent rims from damage.....Errrrmmmmm I am not very good with tyres....Bro VR...Can elaborate ah?? 40 series means the tyre has hard sidewall?
