Tonnka rear billet lower control arms.. need help
BlueSamurai
hello
Wondering if anyone is using this. I just had a set installed in my Mirage and i hear rattles and metallic clonking noises @ slow speed turning and sometimes uneven roads, especially uphill.
I know there's prolly no point asking coz i should go back to the workshop, but i am feeling rather worried, so i thought i would just pop the question, c anyone have had similar issues and know wat was done to resolve. i did the install at a workshop afew days back and it seems like its getting progressively worse, albeit slowly.
Is it possible they weren't bolted down properly?
Let us know what when you find the problem....:driver:
So i brought it down to another workshop today... they didn't have time to take a look at it. however he theorized that it could be the bottom mounts of the dampers since everything is stiffer now. Superpro trailing bushes, hardrace toe and camber arms, and the ends of the billet rear LCA are polyurethane too.
He asked me if everything was bolted back and tightened while the car was suspended abv ground or wif wheels on the ground. he says it makes a difference, and that everything should be tightened only when the car has its wheels refitted and is on the ground again.
Is this really true? i am not quite convinced.... anyone care to weigh in?
Loaded and not loaded does have differences for a car that has very little movement like yours. Afterall rubber is flexible and allows for movement, your PU bushes will make a difference already. Throw in the pillow ball mount, etc.. wah your car race car ka?
Lower arm have bushing, so whether fitted suspended or on the ground should make no difference
Thanks for the feedback. The jam on sat was excruciating even on the 2nd Link so it was a wasted trip. Coz by the time i reach e workshop it was too late to do anything.
Originally before i did anything, everything was okay except for the chassis creaks and squeaks *hey, old car*. and this problem wif the rear left wheel coz the wheel kept giving itself negative camber. Which was the catalyst for me to want to swap out all the bushes to SuperPro. Then i realised Tonnka do sell the rear billet arms wif poly bushes for Proton Satrias and the like and HardRace toe and camber arms are cheaper than the Superpro bushes so what the hell. (ok, i am posting here coz satrias and mirages are almost similar. Mine is the CJ chassis, 1 generation newer but rear suspension components all same)
I starting having sounds in the rear after the parts were installed. a different kind of creak and squeak, and additional rattling and/or clunking noises. Which befuddled me. I know what a difficult customer is like (i used to be a service advisor for my local bmw and porsche dealer) and i dun think i am a diffcult customer. I understand that things are stiffer now and sure to generate operational noises. I can accept squishy bushes and the like but clanking and rattles.. fuyoohh.
Anyway to cut a long story short. this workshop i went to today said that the lower mount of the dampers were not tightened enough. So they checked my rear undercarriage and retightened everything for me. So far so good. Will evaluate for the nxt few days.
Come to think off it, my very old Civic at one time had squeaks and undercarriage noises. After my mechanic tighten all the undercarriage bolt, front and back, the noise went away. Hopefully yours too.....:driver:
So it was just a tightening issue like I said eh? Fuh I'm gooooood.. Bwahahahahah (not)
the noises are gone for the most part. much better before the tightening. but the occasional clunking and rattle still occur. i wonder if this is normal for cars wif polyurethane bushes? Do bear in mind i nvr heard heard these noises before the polyurethane bush and billet arms install.
I am sorry if i come across as a difficult person but the reason why i am asking is i dun wan to be.
Dude, we car enthusiasts are all the same. I am equally difficult when it comes to my own car. So no need for apologies.
As for the PU bushes, I had some PU bushes in my old car but I didn't have noise like you. The noise was caused by other parts of the car moving/rattling more because of the bush. Having said that I've been in the Superpro PU test car that had everything swapped out. Full PU. The ride was pretty awesome and the only thing was the engine vibration was a bit too much because of the solid mounts causing rattling and all. But I don't think your car is having these issues. Probably metal to metal from the billet arms. Try greasing it yourself perhaps?
Sorry for the late reply. A few issues have come up since then. I realised no amount of tightening will rectify the noise, as it didn't come from the bolts not been tight enough. In fact i see the workshop use pneumatic air gun to tighten the bolts up, which cause massive scratches the arms, and also damaging the bolt and nut treads. SIGH. The noises did not cease. in fact they became worse. The reason, (or part of the reason) was some freeplay where the part the coilcover lower mount is bolted to the arm. Only the left hand side. If i wiggle the shocker body, it will hit the arm. thats what causing the noise. Funny i dun have that issue wif the original arms. I have since inserted a small washing to lessen the free play.
To be frank the noise is coming back, this time wif a vengeance. its getting worse, and while i can accept operational noise, i cannot stand knocking. its telling me its metal and metal which... isnt supposed to happen? Nevertheless I have rear superpro bushings and i decided to press them into my rear lower arms... So i got a very prominent workshop in JB today to help me press the arms.
I am from SG and as i didnt drive today i thought they would help me wif the press and i can bring the arms home and install them at another workshop when i have time.
The main point being i wanted to try isolating the noise. If it still have the same sounds then it must be my coilovers, If not then its the arms...
Alas.
Sometimes doesnt mean well known workshop will do a good job. This is what happens when you work with no heart. Now i have to go back to get them to push them out and repress in for me.
Nin na ma eh, best part. I dunno which side is pressed right, which side is pressed wrong now. apparently, 1 side either of the front or rear of both arms, should have a shorter/longer exposed area of bush. I hope i am making sense of what i am saying.
I am also wondering if pushing these bushes and their relevant steel parts out and pressing them in again will spoil them or not. If they become more loose, seriously whats the farking point....
both looks correct to me.... watch closely the black metal some kind of sleeve on the arm where the bushing thicker than the other side...
to me seems like your short arm (dog bone arm) bushing gave way....did u use the one with spherical bearing end? if still stock...that could be your problem...
Got try to lube up the silicone there where the bolts are inserted?
Ok, this is stupid.
the reason the arms look weird, is becoz BOTH of them, are either left or right arms. I have no bloody idea how my car has been running same arms on both sides all these years, and nobody, nobody noticed until this bushing thing came about. So the bushings were pressed in properly (my apologies).
I mean, if you line them up side by side, they are supposed to look symmetrical, but they don't, so this means that both left and right arms are not identitical, dun share the part number. I mean, some cars have identical L & R arms, not this one.
As you guys know, i have been having some problems with the Tonnka billet arms with a whole load of metallic clinging, and/or tick tocking noises. I do love the arms but this won't do. I have been told shit that "oh old car like that one la" and "oh now yr rear so stiff, so now all the weaker points start to flex" "aiya old car got sound here and there inevitable"
Lj lo. where got such thing one. I am not a picky nor unreasonable person. I can understand operating noise, but if there are metallic noises, its definitely a no no. So in my quest to isolate the noise, thats when i had my original rear arms pressed in with SuperPro bushings, and all these drama got unfolded.
Now how did i end up with this SuperPro bushings? Because when i wanted to get the Tonnka arms, they were out of stock and not in production. So i bought and had the bushings shipped to me. Then not long after, i was contacted and informed that they were in stock again. Knn. So ok, buy.
Anyway, so i was back to the workshop on monday, i did a quick search and my fears were confirmed. Part numbers for rear arms are not the same, so though physically i cannot see for real, I now know that L & R arms are different. Funny enough, there is no L & R markings on both of these arms of mine, so i cannot assert whether they are left or right. But by eyeballing when the tech tried to install them back on my car, the right side one doesnt seem to line and and he seemed like he needed to force in to mount wif the knuckle.
Anyway i had them installed. i mean if the car ran these arms for 4 yrs, then whats an hour more. Guess what. Noise gone. So i drove to a scrap yard, managed to get a pair of CB3A arms (they have L & R marking, zzzz) , drove back to workshop disassembled everything, pressed out the SuperPro bushes and pressed them into these new arms.
So, end result, problem solved.
Btw is anyone running Evo3 rear lower arms on their cars? i just realised that i could have gotten Evo3 arms instead of the CB3A ones. So wondering if they are a good upgrade.
Cheers.
Why can't you go back to Tonkka and f*ck them upside down?
Because these are the same production arms used in other Protons and nobody has experienced issues, only me. I am driving a CJ4A Mirage but then again, all share rear suspension components.
Anyway they have been very kind enough to take a look at this issue, and compare it with my original arms. So all is good!
As much as i am abit irritated, I think we should all resolve our problems amicably. no need for f*cking la. Not my style...
A thread every 60 seconds
