anyone?
---------- Post added at 09:29 AM ---------- 6 hour anti-bump limit - Previous post was at 09:27 AM ----------
sorry, i never done overhaul before..
so wanna learnt..
why overhaul got top or full set?
i thought overhaul refers to a process whereby it cleans almost everything in the engine..
which is better?
top or full?
pv6 got 2-3 belts, cant remember, aircond, alternator & power steering.
yes overhaul there are 2 types, those emitting white smoke from exhaust can just change the oil seals & gasket known as top overhaul, meaning only open the engine head.
full overhaul will dismantle your whole engine leaving the engine block inside, some mechanics will take it out too. I did a full rebuild on my engine the last time it was worth it at least engine can lasts another 10 years.
if u ask me of course full overhaul will be better if u have the funds, if not top overhaul will just do fine.
---------- Post added at 10:20 AM ---------- 6 hour anti-bump limit - Previous post was at 10:18 AM ----------
The V6 is a pain in the a** even just to change the plugs. So many things to remove, so is better you change whatever you need to. As for plug cables not too sure, better bro. Danz comment on this.
Some car have different belts to run air con, alternator and so on and some just one belt runs all. If have not change before might as well change now since opening up
---------- Post added at 09:58 AM ---------- 6 hour anti-bump limit - Previous post was at 09:54 AM ----------
Other then those mentioned by bro. Danz, I think you need to change the internal oil seals too. Tensioner and bearings if have?
---------- Post added at 10:01 AM ---------- 6 hour anti-bump limit - Previous post was at 09:58 AM ----------
Usually if your pistons and rings are still in good condition they will do a top overhaul. Remove only the header de-carbonize, grind the valves, clean up and put back.
If need to change pistons and/or rings then is full overhaul
yes unker u are correct, it could costs up to rm360 for workmanship alone to change those plugs, so must as well change at one go, plugs & cables.
timing belt set will include 1x timing belt, 5 oil seals & 2 tensioner bearings.
