In-Car USB & Audio/Video Aux Extension Cable for General Vehicles
ICE -In Car Entertainment
autocrazee
May need modification to fit some vehicles
This extension cable is meant to plug into the existing trim (Modifications may be required for some vehicles). Please note that your head unit must already have support for USB (rear) and also Audio/Video RCA inputs for this cable to work.
Requirements
  • Available trim plug space
  • Rear USB input on your head unit
  • Rear Audio Video aux inputs (RCA)
Package Contents
  • Generic USB & A/V Aux Extension : 1 unit
Warranty
  • 1 Year [/URL]
BUY NOW
can watch movie using it?how to turn it on since no cable for power?
Yes, provided your device supports audio & video out through the 3.5mm aux lead.
does the device will display image if the yellow rca connected to external screen monitor?
Yes, provided your device supports video out via the 3.5mm audio/video aux lead.
Red and White RCA for audio, yellow for video.
---------- Post added at 10:57 AM ---------- 6 hour anti-bump limit - Previous post was at 10:31 AM ----------
The power should be from the device it is connected to.
Hi,
Unfortunately I do not have any data for the Almera original radio.
Regards,
David
if I only hav RCA cable then the USB port can read read thru the extension or not?
Cannot. You need rear USB input for USB to work. This cable is just an extension and a port.
---------- Post added at 11:47 PM ---------- 6 hour anti-bump limit - Previous post was at 11:47 PM ----------
bump!
A thread every 60 seconds
