Knuckle conversion from 4 lugs to 5 lugs
jeheyr
834
19
5,018
Ampang Jaya
community.webshots.com
tq bro...but thats not my car...only a sample, but exactly like that.....only 4 lugs..mine taken out from s13 if not mistaken....wats yr RP01 JJ? 7.5/8?
erm, little bit confius lol...
if mech said to fit disc i bought need at least offset 31, thats mean it will fit with offset 40,42, 32, 35 kan?
if my rim only 7.5j with offset 40 and 1" spacer, is it posibble to fit the disc?
NeuroOne
WFH
2,078
181
Putrajaya
nope.
u nedd rims with offset 31, 30, 25, 20, etc...
not lower than 31.
so with ur 40 offset rims, u need 10mm spacer to get 30 offset.
NeuroOne
WFH
2,078
181
Putrajaya
hurm, should spacer will solve the problem? (sorry noob Q)
im sure 1" will not enough..
1 inch = 25mm.. anyone, any advise?
i think 25mm is too big and may cause failure on wheel bearing for daily driving..
i may have a little effect on bearings, i guess.
if u wanna buy 1" spacer, buy those 1" spacers with lug nuts.
if u only wanna get 10mm spacers, then normal spacer with holes are ok.
buy 10mm spacer is enuf i think coz if u buy 1" spacer, ur rim + tyres will be keluar too much.
tyres will hit ur fenders, if ur car is lowered and during bumps..
DanzEterna
15,910
3,371
www.primeperdanaclub.com
i bought 5mm spacers from sparepart shop rm15 per pc only...
mech say cannot use 10mm 5mm x 2 pcs....cos the wheel lug wont be tight enuf...so 5-7mm is the max.
---------- Post added at 04:37 PM ---------- 6 hour anti-bump limit - Previous post was at 04:36 PM ----------
if u planning to go for custom spacers with lugs......20mm will be sufficient....or max 25mm....
jeheyr
834
19
5,018
Ampang Jaya
mech ask me to customize 1.5" spacer... crazy......
bcz my front wheel only 7j et40.. to fit aristo caliper, u need at least 8.5j and et31(somes said 8.5j with et35)..
base on calculation, 7j wheel only need 0.75"(19mm) spacer to make caliper clearance as 8.5j... and plus 5mm-10mm(mm not inch) to have offset below 35..
to be save, 26mm-29mm spacer should be enough...
this is what i understand... sorry if the calculation/formula isnt true...
btw, the spacer with lug nut as both of u explain... is it same as my attachment below?
NeuroOne
WFH
2,078
181
Putrajaya
yep thats the spacer with lug nut.
well, why dont u try to fit a normal 10mm spacer (spacer without lug nut)
and see if it clears the calipers.
if not, then only u use the spacer with lug nuts.
its not cheap..
---------- Post added at 09:11 AM ---------- 6 hour anti-bump limit - Previous post was at 09:05 AM ----------
and one more thing, the offset calculation is the same for 7" rims or 8.5" rims or any other rim width as the offset depends on the centre of the rim.
so, 7" rim or 8.5" rim will still have the same centre position, and if u more 30mm outwards (to get 30 offset), it still the same.
the difference is only the extended part of the 8.5" rim compared to 7" rim which is narrower (kurang lebar)..
NeuroOne
WFH
2,078
181
Putrajaya
it was only rm5 per pc.
now got some tyre shop selling for rm10 per pc.
and yes, i still can screw wheel nut nicely.
DanzEterna
15,910
3,371
bro..the best is to get 8/9jj with offset 30++ rather than u pening deciding on those spacers....
even if u using customs spacers on 7jj it will look funny....
---------- Post added at 12:47 PM ---------- 6 hour anti-bump limit - Previous post was at 12:45 PM ----------
is it possible for me to use 2 x 5mm (if 10mm not available) spacers on 1 side? any side effects? wobbling?
l2s_turbo
1,068
154
I know a fren is selling his 17" Work VS rim.. front is 8jj with offset +34 rear is 9jj offset +36...
you interested bro jeheyr?
l2s_turbo
1,068
154
It's bro myperdana's rim.. i think let him intro himself ba.. haha.. :biggrin:
A Post Every 5 Mins
<a href="http://www.zerotohundred.com/newforums/showthread.php?p=1887311"><img border="0" src="http://www.zerotohundred.com/features/audi_a4_avant/banner.jpg" width="500" height="150" alt="Drive: 2006 Audi A4 Avant FSi CVT"></a><b><br>Cents and Sensibility.</b><p><b>Audi A4 (B7) Avant 2.0FSI CVT<br></b>Story by: The Necessary<br>Photos by: Tom</p><table border="0" width="600" cellspacing="0" cellpadding="0" id="table1"><tr><td><font size="4">I’m really not sure what this car wants to be...
