Knuckle conversion from 4 lugs to 5 lugs
NeuroOne
WFH
2,078
181
Putrajaya
that's also what i meant.
first u asked if there are any other hub that fit to Perdana and i typed maybe for Perdana, one can fit in either galant, eterna or eclipse 5 lug hub.
for FTO (which your Wira is using now) to fit into perdana, i do not know.
but, if someone know if Perdana hub can fit into Wira, then the FTO hub can fit into Perdana la.
like this:
FTO => Wira
Perdana => Wira
so, FTO => Perdana
well that's my logic. hehe..
sorry if i gave the wrong answer..
GRexer
GRexer™ KuzTomZ
1,201
10
Puchong
Haha.. It's ok, just some misunderstanding. I've seen a lot of people running around with 5-lugs, kinda malu to like suddenly ask them what setup they are using for the hub/knuckle.
One thing for sure, the FTO setup would not fit the Perdana since the Perdana's setup is more like a double wishbone design. FTO underbody is almost same as Wira/Waja, basically most undercarriage parts could swap over.
mymax
170
72
wait till u get bored with ur rims, then u fall in love with 5 lugs rim. haha.. :thefinger:
but mine is 9 holes, can fit 4 and 5 lugs oso.. hehehe..
actually it's time for me to look for another set of rim (remember about what i told u before?)
now most of the allen keys of the rim are leaking, plus got a bit bent + hairline crack..
and now looking for any monoblock rim i think (while waiting for my tabung ayam penuh laa) :thefinger:
me2kimi
717
276
1,563
Puchong
Hi bro NeuroOne, I understand concept of drill hub for new hole for 5 lug. But removing the hub from knuckle will not damaging the bearing? Just curious coz somebody told me it will damage the bearing after remove hub from knuckle
l2s_turbo
1,068
154
Actually any brakes can fit any car.. just retain your original knuckle.. mod the hub will do.. you can use any rotor and any caliper just that with proper brackets for the calipers will do.. rotor also, redrill the pcd holes and you can use it for your car already.. i've fitted GTO 4 pots to perdana (normal la), i've fitted RVR turbo front brakes to picanto, i've seen my fren's old nissan SSS fitted with Porche Cayenne 6pot brakes.. so i guess there's nothing impossible in the world of modification applies.. just that to make sure your mechanic properly secure the caliper with good brackets and rotor.:rolleyes:
GRexer
GRexer™ KuzTomZ
1,201
10
Puchong
Yeah.. I do realise that, but am referring to the knuckle part. :biggrin: As a badly done knuckle might bring vibrations, so, ingat knuckle want to use OEM parts without modifying.
Brakes, well, provided the brackets are done nicely, it's true any car can fit almost any brakes. :driver:
NeuroOne
WFH
2,078
181
Putrajaya
no it will not damage the bearing.
coz the hub is one whole assembly which the bearing is inside the hub.
u just unscrew 4 nuts and the hub can be taken off the knuckle.
example of knuckle and hub
(picture from Mitsu Eclipse, cant find Perdana but basically the same)
1. knuckle
2.hub
l2s_turbo
1,068
154
1. knuckle
2.hub
Oooo.. then mine should be modify hub.. got mixed up already.. thanks for the pics education.. so as i was saying mod hub can le lo.. haha.. gotta edit previous misleading post..
me2kimi
717
276
1,563
Puchong
Ooo...OK. Maybe perdana hub design is like that. But for some car with mcpherson type, it need to be pump out bearing to get access to hub. Pump out the bearing is the process that killed the bearing.
My brother face this problem when want to convert 4 to 5 lug honda. Safer solution is change whole knuckle assy with hub.
---------- Post added at 12:19 PM ---------- 6 hour anti-bump limit - Previous post was at 12:18 PM ----------
myperdana
70
6
508
Johor
ok .. now this interest me .. my rim is 9 hole and i think i can start doing the tebuk as im having a plan to change 5 holes rim in future... since ma rim is 9 hole, i can still use the same rim after tebuk . nice ..
bro l2s_turbo ... another appointment coming away .. update me tha cost :(
NeuroOne
WFH
2,078
181
Putrajaya
do it!
later can find many nice 5 lug rims..:biggrin:
l2s_turbo
1,068
154
Told you d.. just do it to prepare for future nice rims..hehe.. i'll let you know the cost again.. :driver:
evo3
1,796
24
5 lug is nice. At first i use the converter from 4 lug to 5 lug but the rim wooble so in the end, i just tebuk.
myperdana
70
6
508
Johor
converter aka spacer bro?
---------- Post added at 03:44 PM ---------- 6 hour anti-bump limit - Previous post was at 03:43 PM ----------
try this dude... its awesome if u put this on your perdana... hehehe...
wuhooo .. nice bro. and its 4 holes
kelvin_8606
96
6
1,508
(as on conversation with the mech)its mod on a 700hp monster satria gti... owner is using cayenne 8 pot brembo front n rear as well...i ask d mech but mech said dunno wut rotor he's using. he came in for dyno only...
l2s_turbo
1,068
154
Nice..he might be using back the rotor but just redrill the holes..
---------- Post added at 05:27 PM ---------- 6 hour anti-bump limit - Previous post was at 05:26 PM ----------
Drill will be better than spacer converter unless the spacer converter is precisely done by cnc machine..
Hi all Sifu2
I now driving wira 1.5 sedan using waja front kyb gas absorber with wira SE spring and rear using kyb gas absorber with wira 1.6 spring. Now I get front 3 finger rear 2.5 finger. But when drive in highway feel like abit float, duno whether is stiff or float like not stable.
1. Is it rear absorber is too soft(last year change KYB gas but still soft when pressing rear by hand).
2. I want to lowered my car, if I get sport spring can I get lowered since I am 4g15 engine with big...
