Mercedes E-Class Advertisement: Just Hanging Around
keshy
528
698
1,593
Trust me, I had the same expression as you, “WTF, is that real?” Well apparently it is real, the fact that its upside down that is. Taken at the Moscow International Airport, it is not known whether the car is real or made out of plastic, but I reckon it’s plastic. I doubt if Mercedes really would stick half a ton of E-Class on a ceiling. It’s a really good marketing propaganda if you ask me, we found out that the advertisement on the left says ‘This isn’t a plane’, and the one on the right read ‘But the sensations are the same’. Brilliant, those Russians think of everything don’t they.
gtxx
27
waa..is it for sale?i wanna buy then put it in front of my house..hehe..
albagmane
27
if not wrong, last time i spot one which is kinda similar strategy from Mini, which is located along Bukit Bintang road... the car oso stuck at the wall de...
mag9556
2,770
43
1,648
like this also can:hmmmm:
hello sifus,
recently i replaced my car timing belt & water pump & coolant. But after driving@cruising for a while the check engine light(CEL) comes on and stay around 5-20 seconds then goes off. after a while the CEL will comes on again. i dont really notice the weird perfomance during the CEL on...what could be the cause? the mechanic did not install timing belt correctly? timing off?..or maybe some sensors? sensor fault during timing belt replacement? maybe mechanic broke any sensor...
